Vacum leak problem for brakes.
Postby andyling » Sun Feb 12, 2012 2:22 pm
so my car is bluetop 4age, idel temperature running low at 60c,normal driving only goes up to 70.
doesn't any any cooling problem, if there is only two things I know could resulting this, the sensor? which is unlikely.
trying to get some trd thermostat, but trade price is 150+, really?
Done!
Now, got to fix a vacum leak for my brakes, every time I brake my engine revs up and I can hear vacumm leaking nosie every time I turn the engine off. shit.
any ideas?
andyling
Postby Grrrrrrr! » Sun Feb 12, 2012 2:52 pm
Dont waste your money on a TRD thermostat, just buy a decent brand (eg Toyota Genuine) standard one. And make sure you get the right temperature one unless you like high motor wear and high fuel bills.
Grrrrrrr!
Postby Dell'Orto » Sun Feb 12, 2012 2:56 pm
Might have a TRD thermostat in there now if it stays that cold. Could explain why your car uses so much fuel
Postby Bling » Sun Feb 12, 2012 3:46 pm
Yeah valid point!^^
As for buying a TRD one, they are designed for racing situations I imagine, not just driving to the shops and back. So if anything will do more harm than good as mentioned.
Postby andyling » Sun Feb 12, 2012 4:24 pm
any ideas on how muc the toyota ones will cost roughly?
I assume I get them directly from the dealer?
andyling
Postby Bling » Sun Feb 12, 2012 4:46 pm
Yeah your local toyota branch should stock that sort of thing, I don't imagine it being much. Never priced one up myself though. Just give them a call if you don't have time to pop in.
Postby Al » Sun Feb 12, 2012 5:17 pm
I had to buy one for my car at Blenheim Toyota, forgot to get it for my freshen up when we dropped the motor.
Thermostat and gasket TGP.
$45.59 incl gst
Al
Postby iOnic » Sun Feb 12, 2012 5:19 pm
^ Bout what I paid for the one in my Corolla.
Postby allencr » Mon Feb 13, 2012 6:14 pm
I'd NEVER get a thermostat from from the dealer, just like I'd never get wiper blades, battery, tires, oil, alternator, starter, hoses(except for factory only heater stuff), belts, plugs & plug wires!
That TRD thermostat is beyond belief.
http://www.stant.com/Consumer-Products/Thermostats/
allencr
Postby rollaholic » Mon Feb 13, 2012 6:47 pm
and given the temp it opens at you could probably just throw the old thermostat away and say its got TRD-equivalent :P
Postby sergei » Mon Feb 13, 2012 7:40 pm
allencr wrote:I'd NEVER get a thermostat from from the dealer
Thermostat is one of the things I would definitely buy genuine.
The quality of aftermarket ones is shocking - they would fail after 1 year or so (usually stuck open).
Postby Leon » Mon Feb 13, 2012 8:22 pm
ah, well, I'd be emailing Toyspeed Sponsor Mark ... and getting a genuine Toyota one from him.
In fact, that's exactly what I did this morning.
Learnt my lesson. Had an AE92 running cold. Bought repco thermostat. Ran exactly as cold. Bought TGP one off Toyspeed sponsor, car warmed up to normal nice and fast then stayed there.
Link to thread where he is pimping his wares
viewtopic.php?t=66290&start=20
Postby matt dunn » Mon Feb 13, 2012 8:29 pm
Nothing worse than having a problem, buying a cheap part to fix it and them when it doesn't work you still have no idea is that part is the problem or not.
Put a decent one in there and know that that part is now not the problem,
rather than save $5 or whatever.
Postby Mr Ree » Mon Feb 13, 2012 11:15 pm
Amen to that.
wak thud gush!
Mr Ree
Postby rollaholic » Tue Feb 14, 2012 6:34 am
i've fitted heaps of aftermarket thermostats and never had a problem that wasnt of my own making (didnt bleed it properly or w/e)
that being said its typically tridon, which are pretty similar (retail price wise at least) to genuine - so why wouldnt you get genuine in this case.
Postby andyling » Tue Feb 14, 2012 7:06 pm
Al wrote:I had to buy one for my car at Blenheim Toyota, forgot to get it for my freshen up when we dropped the motor.
$45.59 incl gst
yep that's what i paid for too, good deal consider aftermarket ones are 30+ a set anyway.
was a mission to get the thing changed, had to adjust the starter motor. but yeh done, car warms up very quckly. the old one was stack at open.
Now, got to fix a vacum leak for my brakes, every time I break my engine revs up and I can hear vacumm leaking nosie every time I turn the engine off. shit.
any ideas?
andyling
Postby Grrrrrrr! » Tue Feb 14, 2012 7:12 pm
Brake booster is $&#$%, replace it, and test the check valve too.
Grrrrrrr!
Postby andyling » Tue Feb 14, 2012 9:36 pm
that sucks, brake booster? these things don't brake often do they?
I am thinking on vacuum lines etc. what you mean by valves?
andyling
Postby AE82 FXGT » Tue Feb 14, 2012 10:52 pm
This. In my GTZ I went through a CPC and a Tridon thermostat before buying genuine which lasted way longer. The other ones lasted a month or two then my car would run cold. Now I only buy genuine.
andyling wrote:that sucks, brake booster? these things don't brake often do they?
There's a one way check valve that will be inline/inside the vacuum line going to your brakebooster. Make sure air goes one way (toward the engine) and not the other way.
AE82 FXGT
Postby Grrrrrrr! » Tue Feb 14, 2012 10:55 pm
Its a bluetop 4age, so its like 25ish years old. Shit is going be failing quite regularly.
brake boosteris the big round black thing on the firewall of the engine bay behind the brake fluid resv.
There will be a vacuum line going from the brake booster to the manifold, somewhere in that line is a one way valve that should stop air leaking back into the booster after the engine has sucked it out. Make sure it works.
Grrrrrrr!
