TRD Dash
TRD Dash
Postby Makaveli » Thu Mar 08, 2012 5:16 pm
Hi,
I am thinking about buying a TRD dash with around 9000km. My car done around 160,000km. Is it possible to adjust the TRD dash to match my car's actual KM travelled? It's old style odometer reading - not the digital one. Who does this service in Auckland?
Thanks
Makaveli
Postby Quint » Thu Mar 08, 2012 5:23 pm
You have to take it to a legit instrumentation place to get it done propperly....
Or just get a pin and flick the numbers. Be careful not to slip and scratch them tho.
Quint
Postby Makaveli » Thu Mar 08, 2012 5:24 pm
Is there one in Auckland? I would like to get a quote for it before i buy the dash.
Makaveli
Postby Bling » Thu Mar 08, 2012 5:40 pm
I wouldn't even bother personally. Car jam will show a massive drop in mileage, but that's about it. Unless it's a diesel I don't think it matters what the odometer says.
Postby Mr.Phreak » Thu Mar 08, 2012 5:42 pm
Mr.Phreak
Postby Makaveli » Thu Mar 08, 2012 5:46 pm
Mr.Phreak wrote:http://www.robinsoninstruments.co.nz/
Thanks! I will give them a call tomorrow.
Makaveli
Postby Dell'Orto » Thu Mar 08, 2012 6:06 pm
It doesnt matter unless you try and pass off the car as genuinely having less k's. But yeah, Robinson Instruments will sort it out
Postby gt4dude » Thu Mar 08, 2012 6:20 pm
i was wondering on a dash that has an electronic speed signal, can u just apply 12v to it so that the needle goes right up to 180kph and the ODO numbers tick over for you??
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby iOnic » Thu Mar 08, 2012 6:45 pm
Speed signal is almost always a waveform and probably goes through a control unit or two before it gets to your dash so giving it 12V won't achieve much.
Postby ee904age » Thu Mar 08, 2012 6:45 pm
AFAIK digital speedo's work on a low voltage pulse signal, so applying 12v to it will probably just end in snap crackle pop.
EDIT: Beaten to it.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby sergei » Thu Mar 08, 2012 6:46 pm
gt4dude wrote:i was wondering on a dash that has an electronic speed signal, can u just apply 12v to it so that the needle goes right up to 180kph and the ODO numbers tick over for you??
If the signal is electronic (ie not cable) it will be square wave 12V.
Postby Stott69 » Thu Mar 08, 2012 7:32 pm
Ahh so you are on here too. Just remeber that once you convert the price and add post you'll be looking at $1000 at lest.
Stott69
Postby Makaveli » Thu Mar 08, 2012 7:41 pm
Lol small world bro
Makaveli
