4agte Big port or Small port?
Postby mlewis » Thu Mar 15, 2012 12:01 am
Brought a 4age red top small port engine and gearbox for $160 off trade me as I needed sump and throttle body and will split and sell whats needed.
My questions which is better for a 4agte street driven car, with some track work on the odd occasion. Big port or Small port
Is there a major noticeable difference between the too or are they only margin able?
Current head on engine is a early big port 4agze
Any ideas and advice is more then welcome as I've only ever worked with a 20v bt
mlewis
Postby thegreatestben » Thu Mar 15, 2012 12:31 am
Small port has external oil drain from head.
thegreatestben
Postby mlewis » Thu Mar 15, 2012 12:37 am
this mean i can run oil drain from turbo to head? or those oil lines for a catch can?
mlewis
Postby stolic » Thu Mar 15, 2012 8:53 am
mlewis wrote:this mean i can run oil drain from turbo to head? or those oil lines for a catch can?
Nope, it means that you will have an extra oil drain at the back of the head which drians oil back to the bottom of the block (if using the corresponding small port block) or you can direct it back to the sump in the same fashion as you would a turbo oil return. Toyota added this to prevent oil pooling in the head with spirited driving, which would lead to less oil in the sump which can cause starvation. having said that, a few people have just blocked this drain on some conversions and had no issues.. tho I'd be inclined to kee it myself.
as for your choice, I'd pick the small port. should be (slightly) nicer to drive off boost... also if I'm not mistaken, I recall reading that bigport cams can yeld small power gains when put into small port heads?? I'm sure a quick search here or google could confirm this
ImageTA22-build - TA22-blah
I envy those with little interest in cars, for they have money and spare time.
stolic
Postby Vertigo » Thu Mar 15, 2012 12:12 pm
the small port for an average turbo project, the bigport when going to maximum power. also, if doing this, throw away the stock intake manifold and tvis, and make one that is similar to the smallport design, ie. 4 large runners vs 8 restrictive ones.
and yes, bigport cams are slightly more aggressive, so grab a pair for a bit of extra power at very little cost.
TVIS just kicked in, yo!
Vertigo
Postby XSVWGN » Thu Mar 15, 2012 12:51 pm
I would keep the 4agze engine you have intact mate. your only wanting a 4agte to be street driven and not after huge power. You will be quite suprised when your setup is all up and going with how responsive it is. small turbo will spool at lower RPM and good for street use
Matt
2008 Kia rio - work car
XSVWGN
Postby THA SHZ » Thu Mar 15, 2012 1:18 pm
Vertigo wrote:the small port for an average turbo project, the bigport when going to maximum power. also, if doing this, throw away the stock intake manifold and tvis, and make one that is similar to the smallport design, ie. 4 large runners vs 8 restrictive ones.
and i call bullshit to that sir 8) makes no actual difference just slightly nicer drive , been proven , its more a placebo effect :lol:
THA SHZ
Postby headshotnz » Thu Mar 15, 2012 9:08 pm
XSVWGN wrote:I would keep the 4agze engine you have intact mate. your only wanting a 4agte to be street driven and not after huge power. You will be quite suprised when your setup is all up and going with how responsive it is. small turbo will spool at lower RPM and good for street use
Matt
This man speaks with experience :lol:
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Re: 4agte Big port or Small port?
Postby Crucible » Thu Mar 15, 2012 9:15 pm
mlewis wrote:Brought a 4age red top small port engine and gearbox for $160 off trade me as I needed sump and throttle body and will split and sell whats needed.
So do you already have a 4agze? Smallport ze generally give better off boost driveability having slightley higher compression ratio.
Crucible
Real Life Mechanic
Postby mlewis » Thu Mar 15, 2012 9:48 pm
Already have a 4agze but its the big port aw11 version, hearing of Matts beast, I'm looking forward to the T3 i have on it and seeing how it drives. was bidding on a cheap redtop small port as was looking a cheaper option compared to finding a throttle body and sump, but missed out on the engine and found sump and throttle for $40 so not complaining
mlewis
Postby tsoob » Thu Mar 15, 2012 10:40 pm
20v
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby XSVWGN » Fri Mar 16, 2012 9:26 am
tsoob wrote:20v
sure wont complain with the power i have and im sure TSOOB will say the same with his but given you have an unopened 4agze mark (mlewis) just go with that and tune accordingly
XSVWGN
Postby Vertigo » Fri Mar 16, 2012 11:02 am
alright, ill concede that the difference between bigport and smallport porting is minimal, but it is a difference. the stock bigport intake manifold however is very restrictive.
Vertigo
