Hiace fuses? Success!
Postby FST4RD » Mon Mar 26, 2012 3:09 pm
Work vans dash lights aren't going anymore. It's a 2001 hiace.
Can't find the fusebox though. I drive it at night so don't get a good chance to look. I found the box with the relays and stuff in it in the middle under the dash. Where is the other one?
Also can anyone else tell me if the dash light fuse is connected to anything else in the van and what amp fuse it takes?
Thanks
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Bling » Mon Mar 26, 2012 4:55 pm
Just had a quick look. To the left of the clutch pedal. 10A for guage, which I assume is what you're after. Soon find out when you pull the cover off anyway.
Postby FST4RD » Mon Mar 26, 2012 8:35 pm
Awesome your a champ! :D
FST4RD
Postby fangsport » Mon Mar 26, 2012 9:18 pm
have you washed it or got it wet in a downpour recently?
fangsport
Postby Alex B » Mon Mar 26, 2012 10:44 pm
Tail lights are on the same fuse as dash lights for some toyotas. Most frequent cause of this is someone using the illumination wire as an earth when putting a new stereo in.
Postby FST4RD » Tue Mar 27, 2012 12:14 pm
fangsport wrote:have you washed it or got it wet in a downpour recently?
It stays outside all the time, and it has been raining quite heavily recently. Why's that?
FST4RD
Postby fangsport » Tue Mar 27, 2012 7:58 pm
water gets in behind the window washers, an tracks down in to the main fuse box. a former employer used to aggressively wash the rentals and this was often the outcome.
unclip the drivers side washer, straighten the clip out and seal the washer to the front of van.
history proved that you get a couple of shots at it before electrolisis ?? sets in a corrodes the tracks inside box thus requiring replacement.
fangsport
Postby FST4RD » Wed Mar 28, 2012 2:47 pm
Well checked the "gauge" fuse and it's fine. Was very clean, put it back in after wiping gt and no good still. Everything in the fuse box looked very dry.
Wouldn't be any other fuse?
Perhaps the dash bulb is blown? I would assume that if there are more then 1 bulb it's either a coincidence they blew at the same time or there is a wiring problem?
FST4RD
Postby jaypines » Wed Mar 28, 2012 6:08 pm
have a look at the dash dimmer switch if you have it... might not be connected or broken.
jaypines
Postby FST4RD » Wed Mar 28, 2012 7:12 pm
jaypines wrote:have a look at the dash dimmer switch if you have it... might not be connected or broken.
Im fairly sure it doesn't have one. I'll have a look tomorrow morning though.
FST4RD
Postby matt dunn » Wed Mar 28, 2012 7:28 pm
Alex B wrote:Tail lights are on the same fuse as dash lights for some toyotas. Most frequent cause of this is someone using the illumination wire as an earth when putting a new stereo in.
As above do the tail lights work??
Postby fangsport » Wed Mar 28, 2012 8:34 pm
yip, guilty of that one.
fangsport
Postby FST4RD » Wed Mar 28, 2012 8:37 pm
Yeah tail lights work. First thing I checked since most cars are like this.
FST4RD
Postby FST4RD » Thu Mar 29, 2012 7:19 am
Success! After finding that the van didn't have a dimmer i got frustrated and hit the top of the dash above the gauges... And well I'll be jiggered the lights came back on! I hit it kinda hard so all good. Must have been a loose connection.
FST4RD
Postby cat007 » Thu Mar 29, 2012 7:46 am
Sounds like a perminant fix..... :wink:
Postby FST4RD » Thu Mar 29, 2012 7:47 am
cat007 wrote:Sounds like a perminant fix..... :wink:
I hope so! :lol:
FST4RD
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 12 guests
