can anyone please help me to identify this lsd?
Postby andyling » Sun Apr 01, 2012 3:02 pm
It should be a trd 2 way lsd.
what you guys think? 1 way or two way, is it TRD?
the ratio is 4.778 which is probably right as I am doing 4000rpm at 100kms on 5th gear.
can take more photos if needed.
andyling
Postby rollaholic » Sun Apr 01, 2012 4:27 pm
its external appearance is certainly very similar to the TRD one. its definitely not the standard one, you can be fairly certain its TRD. AFAIK you cant tell if its 2 way or what from the outside - need to be able to see the ramps.
if its going into a car that currently has an open diff, read up on axle lengths - IIRC the non-lsd axles are longer by about 5mm and will cause you all sorts of expensive issues if not corrected.
Postby andyling » Sun Apr 01, 2012 5:37 pm
hi thanks for your help.
yep, I have the whole LSD Rear end, so it's not a problem here.
again, cheers.
andyling
Postby BlakeNZ » Sun Apr 01, 2012 8:06 pm
normally you can see the ramps in that "window" that is featured nicely in the very last photo. have a look at the other "windows" and if you see anything different to that last photo, take a picture of it and we should be able to tell you what it is.
BlakeNZ
