Manifold gasket leaking = boost leak?
Postby l1ttle_d3vil » Wed Apr 18, 2012 10:39 pm
The gasket between my turbo and manifold is leaking and/or the bolts keep coming loose.
Only seems to reach about 10, maybe 12psi now rather than 15psi.
Is this likely to be because of the exhaust leak, and is it likely to do any damage if I drive it like this or just loss of power?
And slightly off topic, any ideas on how to prevent the nuts from coming loose?
Postby Dell'Orto » Wed Apr 18, 2012 10:41 pm
Would make sense to lose some boost pressure if the turbine isnt getting the full whack of gas...though depends how big the leak is I guess.
Lock wire would be the best way, otherwise you can get those ovalised lock nuts (name escapes me right now)
Postby Garreth27 » Wed Apr 18, 2012 10:56 pm
Had the same problem on my starlet so I loctite the shit out of each bolt and so far none has come loose, YET.
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby Crucible » Wed Apr 18, 2012 11:43 pm
Dell'Orto wrote:Would make sense to lose some boost pressure if the turbine isnt getting the full whack of gas...though depends how big the leak is I guess.
+1
Had a small leak @ waste gate on mine and it affected spool up considerably. Spring washers behind flat washers work well too. Dellorto's suggestion would prob be a better way to go.
Fastening supply places usually have a really good selection of locknuts etc..
Crucible
Real Life Mechanic
Postby l1ttle_d3vil » Thu Apr 19, 2012 8:17 am
Big enough to feel it pumping out at idle, and hear the difference in tone :lol:
Will check out what bolt fastners I can find. I have tried allsorts of spring washer (separate and mounted on nuts) but as soon as they heat up they go completely flat.
One of them is a PITA to get to as well and to tighten it properly basically have to pull the turbo + manifold off the car so hopefully I can get a permanent solution!
Postby ee904age » Thu Apr 19, 2012 8:35 am
Use Nordlock washers on them, they are a two piece washer with serrations on each half to bit into the nut/mounting surface and ridges in between the two halves that work against eachother so in effect the nut has to get tighter before it'll loosen off. Should do the trick.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Distrb » Thu Apr 19, 2012 10:01 am
i use these on my turbo manfold. appear to work well
http://www.fun.co.jp/english/products/unut01.html
Distrb
Regular Poster
Postby Mr Ree » Thu Apr 19, 2012 10:28 am
What sort of gasket do you have? If its a fibre type, I would replace it with a stainless steel type, as the former always leak eventually as they cant cope with the prolonged heat of a turbo as well.
wak thud gush!
Mr Ree
Postby RedMist » Thu Apr 19, 2012 1:14 pm
ee904age wrote:Use Nordlock washers on them, they are a two piece washer with serrations on each half to bit into the nut/mounting surface and ridges in between the two halves that work against eachother so in effect the nut has to get tighter before it'll loosen off. Should do the trick.
Problem with Nordlocks and high temp is they fuse the two halves of the nordlock together. Good point is the serrations also fuse into the manifold which prevents them from slipping.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby XSVWGN » Thu Apr 19, 2012 6:34 pm
Sorry for the thread hijack but i have removed my manifold and turbo and found the same thing. I had a steel gasket in there and it wasnt that flash. Bazda mentioned getting the surfaces milled so they were both flat and even. I have found it hardish to find a replacement steel gasket
Matt
2008 Kia rio - work car
XSVWGN
Postby QikStarlie » Thu Apr 19, 2012 7:11 pm
should get away with running no gasket, if you get both the turbo and manifold flanges milled flat. otherwise ive found single layer stainless gaskets the best, but still need both surfaces to be pretty good.
QikStarlie
Postby evil_si » Thu Apr 19, 2012 7:46 pm
XSVWGN wrote:Image
Matt
Yea get both faces milled or surface ground flat,
Ill have a look may have a spare sinle layer stainless t3 twin scroll gasket some were.
If not a lot of heavy diesels use them cat, cummins, john deere, but wandering on in doesnt usualy work, most parts smackers want a model, serial number blah blah blah otherwise unless they are familiar with them its to hard
evil_si
Postby XSVWGN » Thu Apr 19, 2012 8:02 pm
The gasket i currently have doesnt really match up with the ports on the turbo. There is around a 2mm over lap on each end and that has just got a large build up of exhaust soot so i presume that will be restricting flow slightly too
Matt
XSVWGN
Postby l1ttle_d3vil » Thu Apr 19, 2012 10:36 pm
Mr Ree wrote:What sort of gasket do you have? If its a fibre type, I would replace it with a stainless steel type, as the former always leak eventually as they cant cope with the prolonged heat of a turbo as well.
Gasket isn't all that flash either so won't help with the leak. It is just the fibre type, tried to get a stainless one every time I've had the turbo off and just given up and put the original one back on, as the bolts come loose anyway :lol:
Finally found a stainless one on TM, then when it turned up it was for a T3 instead... will have to have another look, stainless one on the dump pipe flange is still going strong so that's definitely the way to go.
Will also check out some of these nuts and washers etc, hopefully get this fixed properly now...
-Matt
Postby AE86fan » Thu Apr 19, 2012 11:10 pm
I had the same problem and it took forever to find the right solution. In the end this is what I did.
1. Make sure the manifold and turbo mate together without the bolts binding, my T2 bolt pattern on the manifold was a little off so I filed a little from the turbo bolt holes, this gave a bit of space for expansion.
2. Get a good quality gasket. There is an outfit in New Plymouth that make gaskets, they made me a high temp gasket (unknown material) that was about 4mm thick, it had a little give in it and takes up any slight differences in the flange surfaces.
3. I tried all sorts of nuts and in the end got factory toyota exhaust manifold nuts that I drilled and lock-wired.
4. Make sure your turbo and downpipe are supported with some sort of brace, I modified the factory AE86 exhaust brace that bolts onto the bell housing.
Its worth fixing right, as soon as mine started leaking the first few times there was a noticable drop in power not to mention the risk of damaging something from the hot exhaust gases.....good luck.
1984 NZ AE86
AE86fan
