RedMist wrote:I'd never switch a CV from side to side. They wear and are stressed to a certain rotation.
I would however rotate your wheels first. Just to see if it's not something like a bent rim, tyre not on the bead correctly.
BattleSnayke wrote:Warped rotors?
FST4RD wrote:I'll check that out...
Other thing I was thinking... If one of the CV's is a bit sloppy or something it would be fine under power as it's loaded up. As soon as I'm braking the load comes off, the slop causes the CV to become unbalanced and cause the vibration?
allencr wrote:2 bad boots!!
Very unlikely.. Figure out what's wrong before you have 2 more.
Switching the CV's sides/directions doesn't sound like a good idea at all, was it accidental or intentional?
True-No-Turbo wrote:What was the reason for switching inners? seems odd.As suggested above they would be worn one way and now being driven in the opposite direction which maybe causing them to bind.
Were the cv nuts done up with a gun? are they tight? A loose wheel bearing can cause the same symptoms also as the flange/rotor/wheel will float off centre but generally you will get brake pulse also.
Ive never come across new cvs that give that problem, you never know though. wont be boots.
