GT4 interchangeablity
Postby Shrike » Thu May 10, 2012 10:38 am
hey guys do the rear st205 drive shafts fit in an st185 setup and if not can I swap the outer cvs from the st205 shafts to the st185 shafts?
And im guessing the st205 rear hubs are the same as the rear st185 hubs can anyone confirm ???
I hate mismatching parts lol
Why dream it when you can live it
Shrike
Postby DeeCee » Thu May 10, 2012 7:23 pm
not sure on driveshaft length, but the CV's should be the same with 26 splines. CVs are the same front and rear, though the GT4 ones are apparently slightly different to the camry CV's by way of having a longer spline length than the camry.
The hubs are different between the st165/185 and st205/215/246 with the hub centre 54mm on earlier models to 55mm on later models.
GT Four Adovansu
DeeCee
Postby Scottie » Thu May 10, 2012 8:27 pm
Should be able to use 185 shaft/CVs. 205 shafts are slightly longer. Unsure if that makes them unusable though.
Scottie
