replacement pillow balls for suspension
Postby tim_blair » Sun May 13, 2012 10:40 pm
i am haveing a very hard time finding replacement pillow balls that cost less than 300 for adjustable suspension
can someone please tell me where to find them
girl: can I trust you?
me: you can trust anything :D
tim_blair
Postby siren676 » Sun May 13, 2012 10:52 pm
Im having the same problem as you with my cusco camber plates.
Best price i could find was $120 for just 1 bearing :(
Ive decided to bite the bullet and upgrade to adjustables as whole replacement camber plates were ~$300
What brand are your adjustables?
siren676
Postby Bling » Sun May 13, 2012 10:58 pm
Ask Bazda
Postby VR-4Squid » Mon May 14, 2012 12:11 am
The old saying "You get what you pay for" is especially true when it comes to precision parts like pillow balls/spherical/rose joints.
Having said that, talk to bazda, he can get decent quality joints for reasonable prices.
SquidInc Custom CARtoons
VR-4Squid
Postby Bazda » Mon May 14, 2012 9:25 am
I sell a whole camber plate with the pillow balls in them for around $300.
Send me a PM and I can sort you out.
Siren676 - Also send me a PM we have coilovers for starlets in stock.
Postby tim_blair » Tue May 15, 2012 11:17 pm
my ones are GAB
tim_blair
Postby jbod » Sun May 20, 2012 3:01 pm
If you need spherical bearings for camber plates etc rose end/tye rods i can help you out if you give me the relevant sizes (: .I work in the bearing industry
jbod
Postby DexGT » Sun May 20, 2012 5:13 pm
jbod wrote:If you need spherical bearings for camber plates etc rose end/tye rods i can help you out if you give me the relevant sizes (: .I work in the bearing industry
The ones Siren676 / me want have an 18mm hole though the ball , the OD of the outer race is 33mm , the height of the outer race is 16mm and the height of the hole thru the ball is 20mm. part number I found is MBWT-18.
DexGT
Postby jbod » Sun May 20, 2012 5:32 pm
Ok have written that down will have a look tomorrow
jbod
Postby jbod » Wed May 23, 2012 7:44 pm
Sorry it doesn't look like I can be much help. The results as follows,
The size is not a industrial standard to any extent. An overseas inquiry came back with we can get them out of japan.however I made the inquiry on four pieces..because that is such a small amount the soul distributor of that bearing wouldn't do me any favors and would be looking at 145bux each!!!!!if I made an inquiry for say ten to twenty of them I'd say they'd be more like 105$ each...if it was a greater quantity they'd probably be substantially less.tho for a small amount including the dhl 2-3day freight it'd be 145each :(
The only other thing is if the price Siren got 120bux from is a bearing distributor in nz give me there name and I will be able to get it cheaper
jbod
Postby siren676 » Wed May 23, 2012 7:57 pm
Place i got my price from was Franklin bearings Ltd in Pukekohe and i think that was their buy price
Ive decided the cheapest option for me is to just go back to factory top hats and get some of bazdas coilovers at a later date
siren676
Postby jbod » Wed May 23, 2012 8:07 pm
Fair enough sorry couldn't be more help mate
jbod
Postby Emperor » Sat May 26, 2012 8:23 pm
Where do you work jbod?
Emperor
