Hey there.
I have just completed a headgasket change on my 1985 Corolla 4A Carb.
I have limited tools as i have just moved house.
The car crank's but won't start. There is spark (tested with screw driver test) and there is plenty of fuel.
I have a feeling my timing is out but my problems are this.
I can't seem to 100% confirm TLC. I can't remove the crank pully bolt to see where the keyway is sitting and I don't have the correct socket to remove #1 Spark plug to work out with screw drive trick where TLC.
Is there a way to find TLC or time the motor without removing these parts? I can find the timing Mark on the pully, at first i thought this mark at 12 o'clock was tlc but when looking at pictures of crank pully's this mark and the keyway are at different points.
Any input on timing or my starting problems will be helpful.
