these are the two coils im looking at buying
the first is the one i want but it says in its instructions that its only for use with an msd ignition,
the second says that it can be used with any factory or aftermarket ignition
they are both the same price
1: Pro Power HVC Coil, Use w/MSD 7 Series
Part No. 8251
http://www.msdignition.com/Products/Coi ... eries.aspx
specs
Turns ratio: 85:1
Primary resistance: .04 OHMs
Secondary resistance: 86 OHMs
Inductance: 1 mH
Maximum voltage: 45,000 Volts
Peak current: 1.1 Amp
Spark duration: 150 uS
2: Blaster HVC, Works w/ MSD 6 Series Units
Part No. 8252
http://www.msdignition.com/Products/Coi ... Units.aspx
specs
Turns Ratio: 100:1
Primary resistance: .02 OHMs
Secondary resistance: 1.38K OHMs
Inductance: 7 mH
Maximum voltage: 42,000 Volts
Peak current: 300 mA
Spark duration: 200 uS
both coils look the same
can anyone give me any reason why the first is said to only be used with MSD ignitions
