5AFE Oil specs
5AFE Oil specs
Postby metal_sean_head » Tue May 22, 2012 2:35 pm
Had a search on the FAQ and couldn't find anything.
I want to do an oil change on the mrs ae101 trueno. 5afe auto.
What oil do i need? 20/50, 10/30?
Whats the oil capacity when i do an oil change? As in how much do i put back in after draining the sump and changing the filter.
I couldnt find much on google.
On dude said 4.2l.
Thanks in advance.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Bling » Tue May 22, 2012 3:06 pm
Never had one, but I imagine it's no different to a 4AFE (cc aside) so should be fine on something 15-40w. I use Castrol GTX in a 4AFE and 4AGE with no problems so far. Unless it has MEGA kms on it or something I imagine 15-40w will suit it too.
As for how much i'd say 3.5L then check dipstick after letting it sit after a quick idle. Then just add more as required. I have never measured it, it's just 'most' of a typical 4L container. That's what I do for above mentioned 4afe/4age. Will always be some left behind so there won't be an exact amount to put back in. 3-3.5 should get you onto the dipstick though.
Postby Kiwi-Corolla » Tue May 22, 2012 3:34 pm
15w-40 is what Toyota recommends, however you can also use 10w-40 without any issues. I use Valvoline 15w-40 Engine Armour in mine and it has been great. Never uses any oil and it's always only a brownish colour when changed every 10,000km.
It'll take between 3.0 and 3.2 litres of oil with a new filter (less if you use your old filter but not recommended).
Kiwi-Corolla
Postby metal_sean_head » Tue May 22, 2012 4:37 pm
Sweet. Thanks.
Thats my job for the weekend.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby metal_sean_head » Thu May 24, 2012 11:17 pm
Anyone know what size socket i need to pull the sup bolt.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Mr Revhead » Thu May 24, 2012 11:57 pm
14mm
Postby evil_si » Fri May 25, 2012 7:57 am
Ive been using diesel engine 15w40 oils in mine and the families cars for years,
St191 corona
Mazda atenza,
Toyota trueno 5afe
Toyota Raum 5efe
Nissan navara z20
Mulitple Turbo 4ages and 4agze's
8)
evil_si
Postby Dell'Orto » Fri May 25, 2012 12:21 pm
Will keep them nice and clean
Postby AE86less » Fri May 25, 2012 12:44 pm
evil_si wrote:Ive been using diesel engine 15w40 oils in mine and the families cars for years,
What's the difference?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby sergei » Fri May 25, 2012 1:09 pm
More cleaning additives.
Postby solitaire » Fri May 25, 2012 2:35 pm
Stupid Question Here: Why wouldn't you want to use diesel fuel in a petrol car? sounds like its a good thing, whats the catch?
{actual question is: Why wouldn't you want to use diesel OIL in a petrol car? sounds like its a good thing, whats the catch?]
AE92, KZJ120, KDJ120
solitaire
Postby blindnz » Fri May 25, 2012 2:59 pm
I could be wrong here, you don't get enough compression to cause iginiton by spark in a petrol engine.
blindnz
Postby solitaire » Fri May 25, 2012 3:02 pm
blindnz wrote:I could be wrong here, you don't get enough compression to cause iginiton by spark in a petrol engine.
Shit... I meant Diesel OIL...
haha that really was a stupid question...
I will have another go:
"Is there any down side to using diesel OIL in a petrol engine?"
it must be friday! :lol:
solitaire
Postby Grrrrrrr! » Fri May 25, 2012 3:44 pm
Most diesel oils are petrol rated also. Just look for the API standard marking . Will have API CD/SG or whatever standard the oils meet somewhere on the bottle.
CD = Compression Ignition (Diesel) standard revision D
SG = Spark Ignition (Petrol) standards revision G
Grrrrrrr!
Postby Mr Ree » Fri May 25, 2012 4:54 pm
I remember when 30/40 was virtually the only engine oil available, and now theres literally hundreds, so its no wonder it confuses most motorists
BITOG is the bible for anyone who doesnt understand much about the myriad of different oils on the market these days and I would recommend to everyone who hasnt already done so, to do the 10 page test, as its fun, and really teaches you a lot in a short time frame.
Then you can start buying the correct oil for your cars, and learn a huge amount from the forum, which, for the record, has some very smart cookies in it :)
wak thud gush!
Mr Ree
Users browsing this forum: Google [Bot] and 52 guests
