KnockLink G4
KnockLink G4
Postby jondee86 » Fri Jun 01, 2012 10:00 am
Anyone using the KnockLink G4 ?? Seems like a handy piece of kit
for not much money, but does it live up to the hype ??
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby jondee86 » Sat Jun 02, 2012 5:50 pm
Anyone using any standalone knock detection on their engine ?
Cheers... jondee86
jondee86
Postby Dell'Orto » Sat Jun 02, 2012 6:58 pm
I think Lith has one? I'm surprised he hasn't commented.
Postby iOnic » Sat Jun 02, 2012 7:32 pm
Got one in my MR2. Tbh it's of no real use unless you are in the habit of getting bad batches of fuel regularly or have a junk tune.
Postby jondee86 » Mon Jun 04, 2012 10:20 am
Yeah... I guess that for $300 I could get a dyno tune, and have the
dyno guy listen with his fancy knockbox. I know that with my home
tune, I'm getting some minor det that I can't pick up by ear. My
thinking was that the Knocklink could pick that up, and I would know
where to back off the timing.
But for sure, once the car has a decent tune onboard, there would be
no further need for the Knocklink.
Cheers... jondee86
jondee86
Postby Lith » Mon Jun 04, 2012 10:56 am
Dell'Orto wrote:I think Lith has one? I'm surprised he hasn't commented.
I have been not forum whoring this weekend, funnily enough because I have been busily using my G4 KnockBlock up till today ;)
The Knocklink is pretty sweet, though they can get a bit overexcited and flash for phantom knock - one of the cars I have been involved with is a Turbo Honda which runs one, and it would sense no knock whatsoever then would light up like a Christmas tree when VTEC engaged.... no matter what was happening with timing, fuelling etc.
That was a little annoying/worrying - I know the motor gets way noisier when VTEC engages and was totally sure there should be none (I was also using my KnockBlock when this happened) but nonetheless it was a little unnerving so resulted in a bit of exhaustive investigation to make sure there were no other signs or potential causes of knock, despite the fact that that much knock on boost would probably be noticeable - if not because the engine would have thrown its bits everywhere.
After discussing with Link, they suggested moving the knock sensor onto the intake manifold as things may have been too noisy where it was - which has since got rid of the flashing, but hopefully not for the wrong reasons.
Another guy I know is having similar issues with a STi, same kind of thing - timing isn't aggressive and he can't hear any knock through his headphones but the KnockLink is flashing the occasional time.... whether that means the KnockLink can be overly sensitive, or fantastically good for detecting knock that you might not is a call I'd not want to make for others.
At this stage I've used them as another opinion on how things are operating, not gospel but could be a useful thing to have around.
2007 Mazdaspeed Axela
Lith
Postby Akane » Mon Jun 04, 2012 12:45 pm
Does the knocklink uses it's own knock sensor, as there was a HUGE talk about the different size of the bore uses different types of knock sensors, more specific to the frequency range that knock will give out. This whole talk spawned from replacing the stock MR2 knock sensor (which blows up often according to the Amerikans) with the GM knock sensor (Which never blows up on the MR2).
Postby jondee86 » Mon Jun 04, 2012 6:37 pm
I'm running N.A. but with fairly aggressive timing. Somewhere down
the line I will get an STM tune. However, I don't want to do that until
I have finished messing around with cam settings, ram tubes, zorst
and intake ducting.
Link recommend a separate sensor for the Knocklink. I would use
the stock sensor for the reason given above. As I understand it, the
factory sensor is "tuned" for the engine, and therefore should give
a better result than a universal sensor.
Cheers... jondee86
jondee86
Postby 85AW20v » Tue Jun 05, 2012 9:30 pm
My brother had one in his Starlet rally car with a 1300cc Suzuki twincam in it. The knocklink would flash occasionally through a stage but not during touring. We found a stone wedged between the sump and the sump guard at the same time as we found a broken engine mount. Fixed the engine mount and got rid of the stone and it stopped flashing.
So yes they do show up problems that might not be engine related.
See ya
Simon
85 MR2 20v
85AW20v
Postby RedMist » Tue Jun 05, 2012 10:11 pm
The old knocklinks used to be triggered by gravel rash on sumps or bash plates. I ended up ignoring mine as it would be triggered every time I picked up any amount of gravel.
I think the knockblock is considerably better tuned to specific knock noise than the older knocklink, but in all honesty I haven't tried one.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Lith » Tue Jun 05, 2012 10:35 pm
RedMist wrote:The old knocklinks used to be triggered by gravel rash on sumps or bash plates. I ended up ignoring mine as it would be triggered every time I picked up any amount of gravel.
The G4 Knocklink is a different thing again: http://www.youtube.com/watch?v=xvewfsDxN54
Lith
Postby QikStarlie » Tue Jun 05, 2012 10:36 pm
wouldn't bother with flashing lights. use headphone feature and listen is the best. and if you can hear knock without any detset/ listening device, its pretty bad knock
QikStarlie
Postby RedMist » Wed Jun 06, 2012 7:07 am
Lith wrote:The G4 Knocklink is a different thing again: http://www.youtube.com/watch?v=xvewfsDxN54
Thanks for the instruction. Didn't realize they had a new knocklink. Saying that I run a conservitive tune and have no need to display knock. (I do however record it, for some unknown reason).
RedMist
Postby jondee86 » Sat Jun 09, 2012 8:15 pm
Thanks for the input. Reality check says the Knocklink is a tuning
tool, rather than an engine monitoring instrument like a pressure or
temperature gauge. So I think I will see if I can get the knock
readout from my ECU working properly, and then just set the timing
a degree or two below the knock threshold. Haven't got a headphone
output on the ECU... maybe next time :)
Cheers... jondee86
jondee86
Postby Al » Sat Jun 09, 2012 9:23 pm
Akane wrote: This whole talk spawned from replacing the stock MR2 knock sensor (which blows up often according to the Amerikans) with the GM knock sensor (Which never blows up on the MR2).
That is because the motor goes first.
Al
Postby QikStarlie » Sat Jun 09, 2012 10:35 pm
jondee86 wrote:Thanks for the input. Reality check says the Knocklink is a tuning
Cheers... jondee86
fire me a pm if you want to discuss na 4age ignition maps, got a few you can look at
QikStarlie
Users browsing this forum: No registered users and 45 guests
