MX73 Cressida power steering woes
Postby fuel » Wed Jun 06, 2012 8:38 pm
Hey guys thought I would chuck this up here to see if anyone could be of any help.
Basically have just acquired an '88 Aus-spec MX73 Cressida with 5M-GE and the power steering is doing some funny things. It has the speed sensitive power steering so has a little ECU box which gets a signal from the trans speed sensor and then modulates a solenoid on the steering rack adjusting the power steering fluid flow/pressure depending on speed the car is travelling.
Well anyway something isn't right with it - it generally has super light and sensitive steering assistance at road speeds but once you slow down to a halt the power steering assistance is severely limited as if it's not quite assisted at all, but you can feel some assistance there. The limited assistance at stand-still is intermittent though, sometimes it has full assistance which is good as that's how its meant to be however the assistance doesn't tone down as the car builds up speed like it should.
Things to note:
- The previous owner had an oscilloscope on the system and could verify the trans was giving the steering ECU a speed signal but the ECU wasn't giving any output to the solenoid on the rack.
- I did find that the solenoid was unplugged from the wiring loom but I figure it was like that because the PO didn't plug it back in after prodding around testing with it. I plugged it back in and it made no difference anyway.
- I have replaced the steering ECU with one from an NZDM 85ish MX73 Cressida which had a different part number but looked identical and had the same plug. Again no difference whatsoever with plugging in the replacement ECU.
- The original power steering pump has a little vacuum sensor/switch on the base of it which has been removed and plugged up with a bolt. I am waiting for a replacement power steering pump with sensor/switch to arrive from NZ and will swap it over to see if it makes a difference.
- Worth mentioning is the wheel alignment is out after replacing a rack end which is probably having some effect on it wandering from side to side at road speeds and generally amplifying the affects of the over-assisted steering.
- When taken for a RWC (basically a WOF) the inspector pulled up the steering dampner as a fail as he felt it was too soft. He explained that it should be like a shock absorber and extend when compressed however I feel if that were the case then the dampner would try and push the steering rack constantly to one side. Having never felt another MX73 dampner I don't know if mine is really soft or not.
Any ideas would be most welcome, thanks!
LOUD NOISES!!!
fuel
Postby fuel » Sat Jun 23, 2012 9:06 pm
sorted. was the rack itself. replaced with another and all appears to be fine again.
LOUD NOISES!!!
fuel
