Bastardised igntion systems
Postby Dell'Orto » Wed Jun 13, 2012 11:20 pm
So in my Corolla, I have an interesting hotch potch of ignition system, running a 5K electronic dizzy, with a Ford ignition module and coil. I think these are from XF era fowlcoons etc. Coil looks similar to this one
I want to replace the coil with a nicer looking Bosch HEC715 that I have here, purely because it looks nicer and will be easier to make the wiring look tidier with. Comparing resistance between coils though, the Bosch one is something like 7.5kohm, and the Ford one is 12.5kohm - will this cook something?
Re: Bastardised igntion systems
Postby sergei » Wed Jun 13, 2012 11:27 pm
Dell'Orto wrote:So in my Corolla, I have an interesting hotch potch of ignition system, running a 5K electronic dizzy, with a Ford ignition module and coil. I think these are from XF era fowlcoons etc. Coil looks similar to this one
If the secondary coil resistance (which is measured in kOhms) is lower, it suggests that the primary (measured in Ohms) will be lower in similar ratio. Lower primary means more current through the igniter.
Postby Dell'Orto » Wed Jun 13, 2012 11:46 pm
Well, I measured it myself so I may have $&#$% something up :lol: One probe on the outlet of the coil, and one on the positive in of the coil - would that be secondary?
Postby sergei » Thu Jun 14, 2012 9:34 am
Dell'Orto wrote:Well, I measured it myself so I may have $&#$% something up :lol: One probe on the outlet of the coil, and one on the positive in of the coil - would that be secondary?
Try and measure the primary resistance, between negative and positive terminals on the coil.
You have measured the secondary (actually I think secondary+primary), but that already gives you a picture.
