Diff coolers
Diff coolers
Postby Shrike » Thu Jun 14, 2012 10:36 am
So the gt4 has a factory gearbox oil cooler (which I will be upgrading to a 10or19 row aftermarket unit with a thermostat using -10an fittings and braided line)
Just wondering if anyone has had issues with the rear torsen diffs overheating esp with more kw output then factory
is there anypoint in setting up a rear diff oil cooler ?
pros cons??
Thoughts
Why dream it when you can live it
Shrike
Postby strx7 » Thu Jun 14, 2012 11:11 am
the rear torsen diffs suck if you are interested in putting power to the ground around tight corners. they put all the power to the inside rear wheel which has little or no weight on it and you end up with very little drive thru the corner.
Postby Shrike » Thu Jun 14, 2012 11:22 am
Even if there shimmed up?
I am looking into an open st165 diff that I will be weilding up for shts and giggles
Will evantually go to a cusco 2way its just a time thing
I know lsds tend to act like an open diff if they get to hot
Shrike
Postby Mr Ree » Thu Jun 14, 2012 1:42 pm
Does the factory gearbox cooler have an external pump and lines going to a small core at the front of the car?
I know the Euro spec JZA80 came with a diff cooler from the factory, to try and combat the sustained high speeds expected to be encountered on the autobahns. But it saying that, I know lots and lots of people who track their uncooled diffs so I cant see it becoming a big problem unless endurance racing is your thing?
wak thud gush!
Mr Ree
Postby edwagon » Thu Jun 14, 2012 2:30 pm
Can't shim a torsen.
They do produce plenty of heat when they are working hard.
They work really well, BUT need weight on both wheels to work as an lsd, otherwise they'll single spin.
So if you have heavy swaybars or do tight, low speed turns where the inside wheel becomes unloaded, it is unable to bias the power to the wheel with grip.
edwagon
Postby sergei » Thu Jun 14, 2012 2:41 pm
Mr Ree wrote:Does the factory gearbox cooler have an external pump and lines going to a small core at the front of the car?
Internal pump.
Postby strx7 » Thu Jun 14, 2012 5:44 pm
edwagon wrote:Can't shim a torsen.
Circut & autocross usage = :(
