but i would guess there is a maximum RPM the dry sump pump will handle?
Factor that in with your engine absolute maximum rpm with a little bit in reserve and start from there??????
the pump will flow 10l per 1000rpm of engine speed. So maximum rpm of 8000rpm means 80l/min.
bzrspeed wrote:the oil pressure should be fine. Pump is set for 50psi at 960rpm and 82psi under load but can go upwards of 100psi which i think may damage bearings.. The rule of thumb is 10psi per 1000rpm isnt it? The pump is used for chevy v8 race engines so a 4cy 2000cc road engine will have no issues.l
Just need to figure out what ratio to run. The faster i spin it the more psi of pressure and the larger the scavange/pump ratio is. As i understand the higher the number the more effective it is?
The pump has a maximum rpm of 4400rpm and will be run at half engine speed, so 4000rpm.
the manafacture has said the oil pump on the engine at the standard ratio of 3.1 sump/pump would give 50psi at idle of 960rpm and 82psi under load. But that is for full race versions of the engine making upwards of 300hp. I will be making 180hp so am thinking it might be too much. I have never setup this type of system before.
The question is do i raise the ratio or decrease the ratio? I have 5 pullies here. I was told the larger the figure the better it is as touring cars and f1 cars run upwards of 8:1.
Users browsing this forum: Google [Bot] and 19 guests
