SW20 S54 gearbox whine
Postby GDII » Mon Jul 09, 2012 9:46 pm
So the gearbox in my MR2 sounds like a quiet race box when its got engine load on it. It has been doing it for years. Probably as long as I've had the car. 4 years or so.
Is there anything to be concerned about or is it just the normal sound of the box and being in an MR2 making it louder than a front engine car
I quite like the sound :oops: :lol: but just wondered if it it was bad.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Dell'Orto » Mon Jul 09, 2012 11:19 pm
As long as the oil level is fine, and it doesnt get worse it's fine. If it gets worse, get a spare one ready asap :lol:
Postby headshotnz » Mon Jul 09, 2012 11:54 pm
Dell'Orto wrote:As long as the oil level is fine, and it doesnt get worse it's fine. If it gets worse, get a spare one ready asap :lol:
Good time for a e series lsd box and a churbro conversion if it does blow up :)
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby GDII » Tue Jul 10, 2012 9:03 am
It hasn't got any worse and the oil levels are fine. I should probably do another oil change seeing as I have enough oil sitting there to be used.
LSD box would be great. Lose a lot of corner speed when the inside wheel starts spinning.
I have never driven a well setup turbo car but I would like to get more power out of my car. I like the instant response my current NA gives so a BEAMS would be a nice upgrade. I'd like to drive a turbo MR2 just to see how it drives.
The only turbo cars I have driven is an '04 Holden Rodeo which had the worst turbo lag ever! and a 93 Legacy RS BC5 which was faster than my car on boost but took too long to get there.
1990 SW20 MR2
GDII
Re: SW20 S54 gearbox whine
Postby Grrrrrrr! » Tue Jul 10, 2012 9:37 am
GDII wrote:So the gearbox in my MR2 sounds like a quiet race box when its got engine load on it. It has been doing it for years. Probably as long as I've had the car. 4 years or so.
check that it has the special rubber tipped bolt in the carrier bracket for the long driveshaft on the back of the motor. I hear they might cause the sort of noises you are talking about.
Grrrrrrr!
Postby GDII » Tue Jul 10, 2012 9:42 am
I don't have this bracket. My left axle is longer with no carrier bearing. That's for turbos only.
1990 SW20 MR2
GDII
