Identifying W boxes
Identifying W boxes
Postby AE86less » Thu Jul 19, 2012 4:27 pm
Some of you may remember the issue I asked about with me onselling an incorrect W - JZ bellhousing. I'm now dubious about whether the box I bought it with is actually a W57. I don't want to be putting it into my ae85 and finding out it has $&#$% up diesel ratios or something.
When I dropped the W55 I expected them to have identical casings/housings. Would this be correct? They are the same shape, but have slightly different 'lines' cast into them. Is there a way of checking without doing via ratios? I failed to get a photo last time I was at the car.
EDIT:
New box has a small, solid circle cast into the centre line somewhere along here that I first noticed:
Also, if you google image W57 Ryanfels' old gx61 comes up on page 4 :lol:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Quint » Thu Jul 19, 2012 4:37 pm
I've got a 55 and 57 at home, i'll try and remember to take some photos of them side by side on the weekend for you. iirc they have a different number of horizontal castings?
Quint
Postby AE86less » Thu Jul 19, 2012 4:39 pm
Ok, so they are different? That's a good start, I was kinda expecting them to be identical :roll:
That would be great if you don't mind.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby wde_bdy » Thu Jul 19, 2012 4:42 pm
Ratios is probably your easiest way to be really sure.
Callum
wde_bdy
Postby matt dunn » Thu Jul 19, 2012 8:21 pm
wde_bdy wrote:Ratios is probably your easiest way to be really sure.
Callum
Since ratios are the only difference it is the only way to tell,
as you can swap housing between them all.
Postby QikStarlie » Thu Jul 19, 2012 9:54 pm
+1 for ratio check. start spinning..
although w57 in front seems to have that bump, and 55 behind doesn't.
QikStarlie
Postby AE86less » Thu Jul 19, 2012 10:55 pm
I see. Maybe that lump is an age thing too.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Truenotch » Fri Jul 20, 2012 12:03 am
Does the alloy sandwich plate have anything to do with it? I'm sure most of the 57's I've seen were alloy.
The ratios are all here: http://en.wikipedia.org/wiki/Toyota_W_transmission
Truenotch
Postby Quint » Fri Jul 20, 2012 9:14 am
I always get bored and forget to count.
*spin spin spin* $&#$%, what am i doing again. :lol:
Quint
Postby Grrrrrrr! » Fri Jul 20, 2012 9:24 am
Quint wrote:I always get bored and forget to count.
ADHD much? :P
Grrrrrrr!
Postby QikStarlie » Fri Jul 20, 2012 6:36 pm
Truenotch wrote:Does the alloy sandwich plate have anything to do with it? I'm sure most of the 57's I've seen were alloy.
doesn't seem like it, w55 in my pic has ali plate. 57 has metal
QikStarlie
Postby ryanfels » Tue Jul 24, 2012 9:04 am
Im pretty sure the alloy vs steel plate thing is an age thing
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
Postby Quint » Tue Jul 24, 2012 10:19 am
ryanfels wrote:Im pretty sure the alloy vs steel plate thing is an age thing
Opps forgot about this thread :)
Checked both my boxes, they are both 57s (the 55 must have gone with the uz *shrug*) one has a steel plate, the other alloy, one has the little circle on top, the other doesn't, i'd say they were a different box, if i didn't know they weren't.
Quint
Postby Mr Ree » Tue Jul 24, 2012 11:05 am
The w58 that came fitted to the NA JZA80 was the steel sandwich plate version, hope that helps.
wak thud gush!
Mr Ree
Postby spoonza6 » Tue Jul 24, 2012 11:16 am
apparently it was mated to a W56 box
spoonza6
Users browsing this forum: Google [Bot] and 29 guests
