Shrike wrote:Ok line from the fuel tank connects to a filter and then feeder pump (700hp) (AN-10 in and out) (both fuel pumps and a filter will be in the tyre well along with the surge tank)
matt dunn wrote:The shape of the surge tank is what matter as much as the size,
need to keep the diameter of it small, and the height of it tall,
and if it hold more than 10L it is too big..
Shrike wrote: 540*330*200mm tank
max height I can have for a surge tank is 200mm
MrOizo wrote:If you're making a custom fuel tank, why not make a tank that incorporates a surge cell inside it? Will save on plumbing and space.
Would a better thought out pick up help here too?
