http://www.mkiv.com/techarticles/filters_test/2/
Quite interesting. No surprises though.
Makaveli wrote:I am bit skeptical about the results of that 3A filter. I mean some other filters were made from the same material (cotton) and of similar construction (probably even same factory in China/Taiwan etc). So I am surprised by the variation in results.
In saying that though, all those filter kits probably have a negative result in the real world ie: hot engine bay.
Unless you make some sort of plastic/carbon fiber induction box to keep the engine heat out & draw fresh cold air from outside the car somehow using some sort of ducting.
I run a TRD panel filter in the standard air box, I would like to think that's the best upgrade for a factory engine.
Quint wrote:Needed to test a sock as a bench mark imo.
Users browsing this forum: No registered users and 34 guests
