by BlakeNZ » Mon Aug 06, 2012 9:58 pm
The car is a jzz30 soarer with stock turbos,3" exhaust, twin dump pipes, aftermarket intake pipes, auto trans, supra 430cc injectors. Motor is relatively low km, and in very good condition.
The car made 257 hub kW DIN(18psi) on the speed tech dyno in April. Recently it had BC 264 degree camshafts installed. The inlet side was fine, but the exhaust side shim clearances were out of spec, so needed new(thicker) shims. We bought cam gears for it too.
Anyway, it made 283kW today, at 18psi, and then adjusting the cam gears ( 2 degrees advanced on the intake, 2 degrees retarded on the exhaust side) yielded another 4.6kw, so a total gain of over 30kW at 18 psi.
This was more than we expected.
