1998 Trueno, reseting Tyre pressure light on dash
Postby brentm » Tue Aug 14, 2012 5:27 pm
Hello, can anyone tell me how I reset the Tyre pressure light on the dash of my 1998 Trueno, I got a flat and when the Spacesaver spare wheel was put on the Tyre pressure light came on about a 2K's down the road.
Thanks.
brentm
Postby B1NZ » Tue Aug 14, 2012 6:20 pm
They have a tyre pressure light?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby 1I1 » Tue Aug 14, 2012 6:24 pm
Don't mean the ABS light?
If it's that, drive on a straight piece of road and the light will go out.
TRD Clicky >>Here
1I1
Postby mjrstar » Tue Aug 14, 2012 6:26 pm
fit 4 wheels and tyres of the same size, then it will go out
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby RobertC » Tue Aug 14, 2012 8:12 pm
tyre pressure light does exist it was an optional extra.
there is a sensor in each tyre including the spare.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby AE111_JAMES » Tue Aug 14, 2012 8:42 pm
dont quote me on this but I believe there is some sort of button underneath the drivers side dash that you press and hold and it resets the light. My work mate has it so can confirm this tomorrow.
AE111_JAMES
Postby jaypines » Tue Aug 14, 2012 9:39 pm
i believe those late 90s toyota dont come with sensors in the wheels. instead they use the ABS sensors to know which tyre is flat by comparing rolling speeds of the tyres.
so as above, fit the tyres back on (same size) and it will reset itself.
jaypines
Postby RUKI » Wed Aug 15, 2012 12:20 am
If that car really does have tire pressure sensors then I have brand TP scanner to scan the sensors and transmit data into car's computer. works on many makes/models.
RUKI
Postby petercad » Wed Aug 15, 2012 7:27 am
I had this on a Fielder of mine.
It uses the ABS sensors to measure wheel speed, and any are different by a small amount (due to low tyre pressure), it'll illuminate the light
Mine was reset by holding s small black push-in switch under the dash, drivers side, near the centre console (might have to get your head in the foot well and look, but it's easy to find). Push switch in, and turn the key to ON position, keep switch pressed until the light goes out and all will be fine
2006 Fielder S, CVT, and immaculate.....
petercad
Users browsing this forum: Google [Bot] and 19 guests
