st215 caldina gtt boost problem
Postby MRDOCA » Mon Aug 20, 2012 5:06 pm
hey, so ive turned my boost up on my caldina to 13psi on each gear.
now the problem...
it overboosts at first hitting 16 psi then drops to 13. holds for a bit then drops way down to 9-10psi.
is this a actuator issue? or a leak somewhere?
really the question is is this common or not?
1997 Caldina GTT, Manual, TEIN adjustable suspension, turbosmart bov, 3" exhaust ***Work in progress***
MRDOCA
Postby MrOizo » Mon Aug 20, 2012 5:08 pm
Have you disabled/bypassed the VSV?
MrOizo
Toyspeed Legend
Postby MRDOCA » Mon Aug 20, 2012 5:19 pm
Yea i did that. Thats why i was a bit confused
MRDOCA
Postby MRDOCA » Mon Aug 20, 2012 7:13 pm
Doesnt do it on 7psi but does it on 12
MRDOCA
Postby gt4dude » Mon Aug 20, 2012 7:44 pm
long line? shitty boost tap?
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby gt4dude » Mon Aug 20, 2012 7:45 pm
i find boost taps only gives me about 2-4psi of stable boost increase on the current wastegate spring pressure
200AWKW / 370NM
gt4dude
Postby MRDOCA » Mon Aug 20, 2012 8:03 pm
hmmm. could be the stock wastegate then? the taps solid used it before without hassle. what have others done to combat this problem?
MRDOCA
Postby MRDOCA » Thu Aug 23, 2012 5:50 pm
Tried another manual boost controller still cant get this to hold more than 10psi
MRDOCA
Postby MRDOCA » Sat Aug 25, 2012 12:52 pm
Any caldina wizards wanna help me out?
MRDOCA
Postby MRDOCA » Sat Aug 25, 2012 5:42 pm
Also where is the diagnostics box in is? 97 caldina? i need to check error codes for something
MRDOCA
Re: st215 caldina gtt boost problem
Postby fivebob » Sun Aug 26, 2012 12:42 pm
MRDOCA wrote:hey, so ive turned my boost up on my caldina to 13psi on each gear.
13PSI is stock the boost level, so I fail to see how that is turning the boost up.
If you've done that with a manual boost tap then all you will have achieved is taking longer to reach the stock boost level, slower to react to boost spikes, and faster drop off of boost in the lower gears where the engine cannot produce enough exhaust gasses to drive the turbo hard enough.
now the problem...
See above, this is normal, especially when using a manual boost tap, which IMHO is the worst thing you can do on a Caldina.
It's not an issue with the engine, it's an issue with the boost control system you have chosen to use. If you must up the boost (and currently you haven't even done this even though you may think you have) you need to use a good quality boost controller, preferably dual solenoid if you want stable boost control.
Postby fivebob » Sun Aug 26, 2012 12:59 pm
MRDOCA wrote:Also where is the diagnostics box in is? 97 caldina? i need to check error codes for something
Below the dash on the right side of the steering column
Postby MRDOCA » Sun Aug 26, 2012 2:04 pm
Thanks fivebob. I was just trying to get rid if the 7 psi boost in first and second.
I'll put it all back to stock knowing this info. Thanks again
MRDOCA
Postby fivebob » Sun Aug 26, 2012 2:40 pm
MRDOCA wrote:Thanks fivebob. I was just trying to get rid if the 7 psi boost in first and second.
If it's only boosting to 7psi in first & second in stock configuration it may be that the stock vsv is closing for some reason, either the engine is too cold, excessive knock, or some other "fault" condition the engine detects.
Postby MRDOCA » Sun Aug 26, 2012 2:59 pm
Oh ok. Yea its knocking quite abit lately. Only on low revs my brothers a mechanic so going to put it on the diagnostic machine. Tried running 98 gas didn't change so must be a fault somewhere. Thanks fivebob appreciate the help still new to toyotas :-)
MRDOCA
Postby MRDOCA » Mon Aug 27, 2012 10:38 am
ok so from what ive read on various sites is that the st215 stock boost is 7 psi in first and second and 12 psi in 3rd 4th 5th.
MRDOCA
Postby fivebob » Mon Aug 27, 2012 2:09 pm
MRDOCA wrote:ok so from what ive read on various sites is that the st215 stock boost is 7 psi in first and second and 12 psi in 3rd 4th 5th.
BS there's no gear detection so the ECU can't regulate boost based on gears.
Postby MRDOCA » Mon Aug 27, 2012 2:39 pm
thats what i thought too but seems everywheres saying thats how it is?
MRDOCA
Postby Al » Mon Aug 27, 2012 2:51 pm
The real reason it will boost lower in the first two gears is there isn't enough load to produce anymore.
Al
Postby Grrrrrrr! » Mon Aug 27, 2012 3:03 pm
What Al means to say is you aren't in first or second long enough to fully spool the turbo. Point it up a steep enough slope and you'll probably get 12psi in second. Unless it is limited by the ECU.
Diff Speed/Engine RPM = Gear Ratio
Grrrrrrr!
