hey guys, got issues with my 2jzgte jzs147 aristo. for some reason, pulling through the revband, as it changes from single turbo to twin, you'll get a surge of power for a second when the second turbo comes online, then car will lose all boost pressure.
if you feather the throttle to keep boost pressure under when the wastegate should limit boost to (say 7 or 8psi or whatever it's supposed to be, so sit at 5-6), and select what gear car is in so doesn't change up, it will pull right through and hold boost to redline, but as soon as go over when the wastegate should limit the boost to, it drops all boost, and can't get it back until you back off and let it drop back to single turbo mode.
any thoughts of where i could start looking to try and diagnose this problem? i've been looking everywhere for a leak, but can't find one.
john
