Sorted out my fuel leaking problem, replaced the injector orings aswel as they were leaking.
And now is cranking over but no spark, have 12v at the ignitor coil, 12v on the lead going to the dizzy but nothing from the dizzy to the spark plugs.
At the same time when i use the the screwdriver up the lead or put the lead on a spark tester theres no spark on the ignitor coil to the dizzy coil.
Anyone have any ideas of what could be the problem? or anyone in wellington thats a wiring guru that doesn't mind popping over to have a look?
Any help is greatly appreciated
