20V cambelt misalignment and bolt fouling?
Postby touge_ae101 » Sun Sep 09, 2012 5:06 pm
hey guys,
just been helping put the engine in the ae82 and noticed a few things. i'm a bit baffled as to what could have caused it but perhaps someone else has had similar problems...
the tensioner is fouling on the water pump bolt and seems to be misaligned with the cambelt? could this be down to the difference between blacktop/silvertop belts/offsets?
also waterpump has had a bit ground out of it so the tensioner clears... poor quality parts?? - see pics
funnily enough all work has been done by an engine rebuilder... we insisted on using TGP parts for the rebuild(s) but we have problems like this (there has been many others over the last 12months)
if anyone has got any info on what could have gone wrong... would be good to know. i'll be contacting mark on monday for all new bits and will do the work myself this time...
touge_ae101
Postby matt dunn » Sun Sep 09, 2012 5:19 pm
the problem will be the parts used,
the BT and ST oil pumps are different in the belt tensioner,
and the water pumps are specific to the BT and ST too.
If you use a BT and a ST part, the belt rubs on the water pump,
as you have found out.
It looks like you have BT oil pump and a ST water pump.
Need a BT oil pump with a BT water pump,
or a ST oil pump with a ST water pump.
You will also find the cambelt covers wont fit.
Postby touge_ae101 » Sun Sep 09, 2012 9:44 pm
Cambelt covers fit fine aye.. not sure what combination of st/bt..
touge_ae101
Postby 85AW20v » Sun Sep 09, 2012 10:38 pm
And isn't there a difference of one tooth in the ST/BT belts - the BT being longer?
See ya
Simon
85 MR2 20v
85AW20v
Postby matt dunn » Sun Sep 09, 2012 11:02 pm
85AW20v wrote:And isn't there a difference of one tooth in the ST/BT belts - the BT being longer?
yes due the the tensioner being in a different place.
Postby Truenotch » Sun Sep 09, 2012 11:49 pm
That's annoying Rhys. Did your old man have to foot the bill for this last rebuild?
Truenotch
Postby jacobrjett » Mon Sep 10, 2012 10:04 am
i may be wrong but thats a hydraulic tensioner which would only bolt onto a blacktop oil pump right? so you must have a silvertop water pump?
or do they have the same mounts for the tensioner
jacobrjett
Postby touge_ae101 » Mon Sep 10, 2012 1:19 pm
Truenotch wrote:That's annoying Rhys. Did your old man have to foot the bill for this last rebuild?
yup. another $5k job which is sub-standard...
touge_ae101
