WHY WON'T THE DAMN KEY TURN?!?!?!!!!!!
Postby Adoom » Sun Sep 16, 2012 6:49 pm
So I removed my ignition barrel.
It has to be in ACC to remove it. But after I removed it, I turned it to "Lock".
Now the key won't turn back so I can't put it back in!?
AFAIK I should be able to turn the key from lock to Start with the barrel out like this.
I can can remove the key.
I have flooded it with CRC.
I have tried turning the key while holding the lever thing up and down.
I have tried turning the key with the retaining pin thing held down(but all that does is hold it in the barrel thing, doesn't it)
Is it suddenly $&#$%? Am I doing it wrong!?
Anyone in the Hutt/Wellington got a spare one(with a key)?
Adoom
Postby Adoom » Sun Sep 16, 2012 6:59 pm
*inserts tiny metal thingy into back of tumblers* SUCCESS!! :D :D :D :D :D :D :D
Adoom
