External wastegate question
Postby snwtoy » Sun Sep 16, 2012 7:23 pm
I've had an external hooked up but not working for a couple of years now (i know i know i'm bloody lazy).
Anyway, do they seize up? The reason I ask is that I have the turbo off at the mo, and was trying to push the diaphram by hand, and couldn't make it move at all. It's a 14psi spring.
If it is seized, am I likely to be able to dissasemble and reassemble after freeing it up, or are there springy things that will go everywhere and I'll never get it together again?
snwtoy
Postby iOnic » Sun Sep 16, 2012 7:59 pm
What brand is it? They're not exactly easy to open by hand so may be perfectly normal. I've seen a couple seize up but they were cheap china shit. Never skimp on your wastegate IMO.
Disassembly is easy. there are only ~5 parts to most wastegates. Hold the unit tightly shut in a vice/clamp. Remove the ring of allen key bolts around the top cover and carefully separate it from the lower cover (carefully because the spring is very strong and will be working to launch the cover off violently - you don't want this)
Postby 92mr2paddy » Sun Sep 16, 2012 8:08 pm
yea they can be really hard to try and push open by hand!! if its a good brand like tial i wouldnt worry but yea careful taking the screws off as the spring has some power behind it, i wouldnt bother taking it apart if its a good brand as it will be fine,
92mr2paddy
Postby snwtoy » Sun Sep 16, 2012 8:52 pm
Hmmm it's cheap:
http://drivenperformance.co.nz/scripts/ ... oduct=1008
Chinese? I assume so? hmmm
I guess if I put everything back together, then have to take it all apart and spend $400 on a Tial gate it will be lesson learned.
snwtoy
Postby evil_si » Sun Sep 16, 2012 8:55 pm
Nope they are very hard to move by hand, i wouldnt be to worried
evil_si
Postby snwtoy » Sun Sep 16, 2012 9:15 pm
Cool, thanks guys, set my mind at rest :)
snwtoy
Postby Shrike » Sun Sep 16, 2012 9:22 pm
if its sezied closed you would be free boosting as it wouldnt open when the spring pressure is hit
if it was stuck open then you wouldnt hit boost at all
Why dream it when you can live it
Shrike
Postby snwtoy » Mon Sep 17, 2012 12:31 am
Shrike wrote:if its sezied closed you would be free boosting as it wouldnt open when the spring pressure is hit
As above, it's never been used. There is no pressure line going to it.
snwtoy
Postby Shrike » Mon Sep 17, 2012 9:30 am
So you have an external gate but no pressure line hooked up
are you still running the internal ?
Shrike
Postby snwtoy » Mon Sep 17, 2012 7:46 pm
No, I'm running no gate, which is why I need to get this one working.
snwtoy
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
