Are these CT20 turbos?
Postby 2jz tt Aristo » Tue Sep 25, 2012 10:35 pm
Hey all, i grabbed a couple turbos for next to nothing to get rebuilt and highflowed, i was told they came off a 2jz which looking at the bolt ups for manifold seems correct.
Problem is there isnt any markings on the turbos to confirm or deny they are CT20's, so i took off the turbine and compressor housing to measure the wheels:-
Compressor inlet:
Compressor outlet:
Turbine inlet:
Turbine outlet:
I found this link, seems to confirm but would like some input from you knowledgeable fellas!!
http://www.turbosupras.com/pages/en/pages/technical/CT20%20turbochargers.htm
2jz tt Aristo
Postby Stott69 » Tue Sep 25, 2012 11:04 pm
Was that the set on trademe? Started at $1?
Stott69
Postby 2jz tt Aristo » Wed Sep 26, 2012 11:16 am
Stott69 wrote:Was that the set on trademe? Started at $1?
Yip thier the ones, came with a box consisting of 2 sets of manifolds, downpipes and intercooler pipes. The only part number i could find was the std bov which came off a 1jz Soarer! But have found there were 2jz and 1jz manifolds, 2jz downpipe and 1jz intercooler piping.
Turbos are in decent nick too.
2jz tt Aristo
Re: Are these CT20 turbos?
Postby Lith » Wed Sep 26, 2012 11:31 am
Looks right - the inducer measurement for the compressor comes across as a little small due to the way you have measured it, the inducer measurement relates to the diameter (even though there isn't a solid "circle" like you were able to use for the exducer) - ~38.5mm is what you'd be looking for on the inducer, I reckon that looks like it is in the right range.
2007 Mazdaspeed Axela
Lith
Postby 2jz tt Aristo » Wed Sep 26, 2012 12:27 pm
Yer it was alittle tricky getting an acurate measurement, i span the wheel to help get the true radius. Im pretty confident they are CT20's.
2jz tt Aristo
Postby Lith » Wed Sep 26, 2012 12:46 pm
Yep, should add the exducer looks bang on :)
Lith
Postby 2jz tt Aristo » Wed Sep 26, 2012 12:56 pm
2jz tt Aristo
