h8wrxs wrote:i THINK** as long as both clutch and flywheel are the same size then theres no problems
AE86fan wrote:Planning on using the 200mm TRD pressure and clutch plate, just not sure if it would work on the 212mm flywheel.
Grrrrrrr! wrote:What gearbox that is it going into?
If its a RWD gearbox it might not have enough clearance for the 212mm flywheel/pressure plate, or the correct spline.
rollaholic wrote:the 200 and 212 flywheels are actually the same diameter i think, just the engagement area is larger on the later ones. i didnt know the GZEs got a bigger flywheel / clutch though.
