rolla_fxgt wrote:We just had the same dilema with our legnum.
Had a few rust holes in the resonator, so took it out and put a straight pipe in, and it hasn't changed the loudness at all, in fact if anything its made it slightly quieter, but it has changed the tone to a higher pitched, slightly raspy one at one particular point in the rev range.
Makes it sound less manly in its sound, like its had its balls chopped off, vs before when it had a bit of deepness to it.
~SlideWays~ wrote:Problem is it Stainless Steel so can't weld it myself.
BZG|Bling wrote:~SlideWays~ wrote:Problem is it Stainless Steel so can't weld it myself.
Why not? I can understand if your whole system is stainless. But I though you could weld stainless with mild steel wire? Hmm, Google suggests that it may be brittle with CO2 gas used but that argon/CO2 mix might be alright.
e30-323ti wrote:You've done exaclty what I did (albeit with a TT 1JZ).
I ended up with the Flowmaster Delta 40 in the middle.
Quitened it up nicely, still had a bit of a drone ~2500 rpm which I put down to the nasty oval chase muffler.
I then bin'd the chase muffler and now only have the Delta 40 at the rear, which a a bit rowdy, but nowhere near as droney as the chase oval.
not much help sorry.....
jacobrjett wrote:sorry to thread jack,
so if resonators make it sound deep without a rasp but dont remove volume,
if i were to decat and replace the mid muffler on my standard ae111 exhaust (with resonators), would i be able to achieve a slightly deeper and more aggressive exhaust tone on my car and keep the stock muffler for stealth look?
~SlideWays~ wrote:e30-323ti wrote:You've done exaclty what I did (albeit with a TT 1JZ).
That's a bugger to hear... guess I'll see if its still droney after fitting something in the mid section.
Users browsing this forum: Bing [Bot] and 14 guests
