Apexi AFCII in my car..What does it do? + Wherego for dyno?
Postby guiltysky » Thu Nov 08, 2012 1:34 am
So I recently got my hands on a mint low km SW20 GT-S and ended up selling my Gen3 BEAMs one.
The car appears stock standard but I found an Apexi AFC II (air flow converter type II) behind the passenger's seat. It appears to be connected to the car via the rear of the rising centre console.
I had absolutely no ideal what this does. It has a volume dial from -15% to 12% in increments of 3%. Been searching around online and can't find anything conclusive about what this device actually does and what it would mean to play with the settings, currently at 12%.
Also wanting to take it for a dyno and tune to see how many horses it's lost over the years and was wanting to know if anyone had a place to recommend.
thanks in advance
guiltysky
Postby dnalunchie » Thu Nov 08, 2012 4:42 am
Take it to Soichi at ST hitec he has been in the tuning seen for ages and knows japanese so is good at tuning older pieces such as that. He is also extremely good at what he does.
If not him then WRC developments or torque performance.
I would stick with st hitec tho. Very good rep
Current: 90 3sfe Corona
dnalunchie
Postby rollaholic » Thu Nov 08, 2012 6:59 am
i expect it intercepts the AFM signal and gives the ECU a modified value, related to the % values on the dial as a way to trick it into adjusting fuelling.
Postby MAC_HATER » Thu Nov 08, 2012 8:33 am
dont you see?
ITS THE SUPREME
i love engrish :D
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby Mr Ree » Thu Nov 08, 2012 9:19 am
AFC=air fuel controller.
They are just a cheap option for a bit of tweaking of your factory tune.
Not something I would use, due to the fact it fools the factory ECU to think something else is happening, in order to get less/more fuel.
wak thud gush!
Mr Ree
Postby Lith » Thu Nov 08, 2012 9:58 am
Mr Ree wrote:AFC=air fuel controller.
Which also results in more/less timing - can result in danger.
PS, loving the Japlish on that - none of my Apexi things had some awesome :(
2007 Mazdaspeed Axela
Lith
Postby Akane » Thu Nov 08, 2012 12:55 pm
The original badboy fuel controller that's made by Apex'i
Just take it out IMO.
Users browsing this forum: Bing [Bot], Google [Bot] and 24 guests
