Silvertop boost handling ability
Postby dnalunchie » Tue Nov 13, 2012 1:50 pm
Out of curiosity how much boost do you guys reckon a stock silvertop could support assuming the proper fueling and a well tuned aftermarket ECU.
I was thinking like 6-10psi?
Also do you think a GT28 turbo would be too big for it or just right if the aim is good low down spool.
IF not the gt28 then which turbo would you recommend and why?
Just doing a bit of research for future projects very very far down the field.
P.S I know the topic has been discussed before but from what I found not the info on boost level specifics and turbo choice.
Current: 90 3sfe Corona
dnalunchie
Postby Shrike » Tue Nov 13, 2012 2:02 pm
The silvia turbos or the td04 would be good sized for response etc
and assuming there is no knock it should be all good
Why dream it when you can live it
Shrike
Postby dnalunchie » Tue Nov 13, 2012 2:21 pm
Shrike wrote:The silvia turbos or the td04 would be good sized for response etc
Silvia uses GT28 I believe.
dnalunchie
Postby Shrike » Tue Nov 13, 2012 2:28 pm
Depends which silvia
The earlier ones uses a T25
Depends what power you want
The s15 uses a T28 off the top of my head and is good for about 180kw I did lots of research into it ages ago ill see if I can dig it out when I get home
Shrike
Postby dnalunchie » Tue Nov 13, 2012 3:30 pm
Shrike wrote:Depends which silvia
thanks
dnalunchie
Postby Dell'Orto » Tue Nov 13, 2012 4:49 pm
There was a project on here a few years ago, I think he ran 6psi on a TD04, and made 130 odd kw. Stock internals, can't remember what fuelling he had. Ran a V5 Link I think.
Postby jacobrjett » Tue Nov 13, 2012 5:09 pm
did you buy a 101?
jacobrjett
Postby CAMB01 » Tue Nov 13, 2012 5:24 pm
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Dell'Orto » Tue Nov 13, 2012 6:28 pm
Thats the bugger....seems my memory is slipping in my old age :lol: Was a really nice looking car in the flesh too
Postby RS13 » Tue Nov 13, 2012 6:47 pm
Early SR20DETs ran a T25G, the later ones ran the T28s. I'm sure either would be well suited to a 4AGE.
Although, you're going to spend thousands setting up a proper fuel system and well-tuned aftermarket ECU but then run an internally stock 20ish year old engine, probably with 200+kms on it? You'd at least want to rebuild it.. but then, you'd be silly not to throw in at least GZE pistons along the way.. what are you planning to do with it?
RS13
Postby Mr Revhead » Tue Nov 13, 2012 8:28 pm
This is why I told you to buy a Corona or Corolla Wagon :P
Postby iOnic » Tue Nov 13, 2012 9:21 pm
Postby dnalunchie » Wed Nov 14, 2012 1:44 am
RS13 wrote:Early SR20DETs ran a T25G, the later ones ran the T28s. I'm sure either would be well suited to a 4AGE.
Just a toy. This isnt going to happen in the next few months but I like knowing how things work ahead of time. Goals are good, they keep you motivated.
I know the STI will spank it but something inside me still loves the idea of a cheesy boyracer levin with a turbo whacked on. Just the kid in me I guess.
dnalunchie
Postby RS13 » Wed Nov 14, 2012 1:50 pm
dnalunchie wrote:I know the STI will spank it but something inside me still loves the idea of a cheesy boyracer levin with a turbo whacked on. Just the kid in me I guess.
Hah, I know what you mean. For all the factory turbo cars I've owned, I still entertain thoughts of throwing a turbo kit on a D or B series vtec EG Civic.. have wanted to for years.. lol. :)
RS13
Re: Silvertop boost handling ability
Postby matt dunn » Wed Nov 14, 2012 10:00 pm
dnalunchie wrote:Out of curiosity how much boost do you guys reckon a stock silvertop could support assuming the proper fueling and a well tuned aftermarket ECU.
With the right fuel and tuning and assuming it is a decent engine to start with I'd say 10 to 14 psi.
Pretty sure Willie's MR2 ran a standard ST turbo before he had it as one on the engines in it.
Postby Lurkin » Wed Nov 14, 2012 11:49 pm
if the cars free, and you have access/ fabricate yourself.. sure why not.
I faced this situation with the ae101 I previously had.
Frankly, for the time/effort/money it was worth putting in forged pistons.
but then, for the time/effort/money of the above, there were cheaper options for a more powerful car, that would likely be more reliable in the long run.
low boost/ high comp... should be fun!
Past casualties
1986 4age liftback (sold)
Lurkin
Postby gt4dude » Thu Nov 15, 2012 8:19 am
you want itsuki's car lol or wataru's car
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby Lith » Thu Nov 15, 2012 9:46 am
RS13 wrote:I still entertain thoughts of throwing a turbo kit on a D or B series vtec EG Civic.. have wanted to for years.. lol. :)
Yeah, for some reason me too even though FWD turbos annoy me a bit. The combination of VTEC + boost makes for a very fun power delivery.
2007 Mazdaspeed Axela
Lith
Postby Flannelman » Sat Nov 17, 2012 10:33 am
What I would do.
New rings, berrings, oil pump. Use upgraded valve springs as stock ST ones collapse under long term boost useage. Custom intake manifold, turbo exhaust manifold.
Use E85 for fuel so uprgading the fuel system is a must and aftermarket ECU. When tuning, the E85 will take more timing both under boost and off it giving greater throttle responce and increased torque/power throughout the rev range.
Select turbo for peak boost between 4-7000rpm. While larger turbos will provide greater power, this would setup will be more user friendly.
I see no reason that 14psi cant be used with this setup safely for a long engine life.
Flannelman
formerly known as Affroman
Postby Rookie » Mon Nov 19, 2012 4:32 pm
I know someone who is running 16psi on a stock silvertop except for 2 head gaskets, I think he uses an early evo turbo. Oh it's in his race car so you know it beaten on.
Rookie
Users browsing this forum: Google [Bot] and 27 guests
