E153 Rebuild
E153 Rebuild
Postby Grrrrrrr! » Sat Dec 01, 2012 8:35 am
Couple of questions..
Is it possible to upgrade the earlier e153 to the dual synchros that the later models came with for sane money?
And anybody got a ball park figure for getting one of these rebuilt with new bearings/seals?
Grrrrrrr!
Postby MilfHunter » Sun Dec 02, 2012 6:02 pm
I'd like to know as well
The later boxes with "proper" syncro's are narrower and lighter. They are easily recognised by a pressed steel 5th gear cover and I doubt you can use anything in them
MilfHunter
Postby Malcolm » Tue Dec 04, 2012 1:15 pm
MilfHunter wrote:The later boxes with "proper" syncro's are narrower and lighter. They are easily recognised by a pressed steel 5th gear cover and I doubt you can use anything in them
Sorry but that's not correct at all.
Lee there's a good post on mr2oc.com about rebuilding an E153, I think it's this one:
http://www.mr2oc.com/showthread.php?t=3 ... ansmission
I'm pretty sure you can switch to the better syncros, I think it's a matter of replacing the whole selector hub and the syncros but I think the gears are the same. There's prices on a lot of the parts in that thread too, probably can get them from Lithia but shipping might hurt
