Hey guys well basically my vvti is stuffed so my bzg isn't very fun to drive at the moment Was told by the mechanic that it's the pulley (intake cam gear?) that's the problem and it will cost over $1000 to fix. Apparently this is quite pretty common problem with 20v 4ages so I want to ask does that price range seem about right to you guys? Seems like a lot to me to be honest but then again I'm not too aware of how much work is needed to replace this.
What are the parts required to replace vvti just the pully itself or is there more to it? How much should I be looking at getting this replaced? Thanks for you responses.
