3SGTE Cam pully dowels
Postby headshotnz » Mon Dec 10, 2012 6:39 pm
Upon rebuilding my engine I noticed both pulleys had 3 different positions you could set them too, has any one experimented with this or know the correct position they should be in.
From what I understand they are for different regions.
A quick Google search showed no results.
Ta
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby iOnic » Mon Dec 10, 2012 7:18 pm
The pulleys are shared between a couple of engines. They are marked on the gears.
Postby strx7 » Mon Dec 10, 2012 9:28 pm
by using the 3 different dowel slots in the cam pulley you can tweak your cam timing by a third of a tooth at a time which equates to 3.something degrees from memory.
Postby DeeCee » Mon Dec 10, 2012 10:26 pm
GT Four Adovansu
DeeCee
Postby headshotnz » Mon Dec 10, 2012 10:46 pm
Fantastic thanks guys, this will give me some thing to work off.
headshotnz
Users browsing this forum: No registered users and 30 guests
