Play in the rear wheels
Postby Stott69 » Sun Dec 16, 2012 2:58 pm
Right guys I've got play in the rear wheels, and not the fun kind that causes smoke. WOF guy has said bearings but I've just jacked the car up and can only see play vertically and not horizontal. Wouldn't bearings give play in all directions? If its not bearings I'm guessing ball joints, but how would be the easiest way to figure which one?
Stott69
Postby rollaholic » Sun Dec 16, 2012 3:31 pm
what sort of car / rear end is it?
play on vertical axis is typically caused by wheel bearings but suspension setup is a factor.
if you can feel the play while rocking the wheel back and forth, and you still think it might be a balljoint it shouldnt be hard to spot. just get someone to rock the wheel while you crawl around under the car with a light and give all the balljoints connect to that wheel a visual. if the shaft is shifting back and forth in it base its junk. bit hard to explain but fairly easy to see if that makes sense?
Postby iOnic » Sun Dec 16, 2012 3:37 pm
If you get someone to work the play while you crawl underneath, you'll be able to see the ball joints moving if thats the cause. I would hold them while the play is worked to see if they are knocking. Wheel bearings can be in one direction (usually vertical) So check your suspension joints first and rule them out.
Edit: the hairdresser is on to it :lol:
Postby Stott69 » Sun Dec 16, 2012 4:09 pm
Its in the aristo, same rear end as a Supra, Soarer and a few others.
Hmm now find some one willing to work my play.
Stott69
Postby DVSMOTORSPORT » Sun Dec 16, 2012 8:42 pm
To determine if its the w/bearings, try jamming between the brake pedal and seat or simply get someone put their foot on the brake, then check for play, having the brakes applied holds the hub in position and eliminates the w/bearing play.
If it is the w/bearing, try adjusting your axle nut, if that doesnt work then you need to replace the bearing.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby holden_fan2005 » Sun Dec 16, 2012 10:05 pm
Have a look in the top arm bushes. Super easy to spot looking over the wheel when jacked up.
Mine were flogged out in the soarer and had play like you've suggested.
holden_fan2005
Postby edwagon » Mon Dec 17, 2012 7:25 am
Which shape aristo?
The 161 and 160s have a swivel bush instead of a bottom balljoint which wears out - same deal as a ba-bf falcon
These things do go through rear wheel bearings too though so could be the bearing, but they tend to start whining before you can feel any play
edwagon
Postby Girvs » Mon Dec 17, 2012 8:10 am
Holden_fan has already commented, but check your upper arm bushes. The Supra failed the warrant on the same thing about two years ago, so I wouldn't be surprised if its the same with yours.
Girvs
Postby rollaholic » Mon Dec 17, 2012 5:15 pm
DVSMOTORSPORT wrote:If it is the w/bearing, try adjusting your axle nut, if that doesnt work then you need to replace the bearing.
by adjust he means, crank the hell out of it with a 2m bar :P
iOnic wrote:Edit: the hairdresser is on to it :lol:
jealous imo :P
Postby iOnic » Mon Dec 17, 2012 5:44 pm
jealous imo :P
Mebbe :lol:
Postby Stott69 » Mon Dec 17, 2012 6:39 pm
jealous imo :P
I may need a longer bar then
Stott69
Postby DVSMOTORSPORT » Mon Dec 17, 2012 8:16 pm
Haha, big ass rattle gun! using a bar sounds like too much exercise
DVSMOTORSPORT
Postby Stott69 » Mon Dec 17, 2012 9:19 pm
DVSMOTORSPORT wrote:Haha, big ass rattle gun! using a bar sounds like too much exercise
that sounds like your offering the use of one? Road trip down
Stott69
Postby DVSMOTORSPORT » Tue Dec 18, 2012 6:34 pm
Thats a hell of a drive haha, we have rattle guns upto an inch, maybe even inch and a half.
DVSMOTORSPORT
Postby Makaveli » Fri Dec 21, 2012 8:54 pm
Trust me mate. Replace your bearing. Toyota tightened my axle nut, it sorta did the trick for a couple of weeks. Then it got back to how it was, squealing. One night it got so bad, I thought the wheel would come off. It sounded like the wheel was moving a bit horizontally. I got the bearing replaced including the hub axle.
I got JZS147, I know all about them.
I had to replace Left Rear one.
Makaveli
Postby Bling » Fri Dec 21, 2012 9:21 pm
Replacing one of mine atm, could feel a bit of a rumble through the spring when spinning the wheel. Mark hooked me up.
Postby Stott69 » Sat Dec 22, 2012 9:55 am
The pain in the arse thing is I've just replaced a spun bearing on the back left, and now its got play after only 3 or so months. Sourcing a set of soarer hubs n carriers at the moment, and a BMC from the same car too
Stott69
