quick, dumb question. 3sge BEAMS
Postby tractionfree » Sat Jan 05, 2013 6:03 pm
hi guys, which end of the fuel rail is the inlet end? throttle body end?
dont ask :lol:
tractionfree
Postby nz_climber » Sat Jan 05, 2013 6:47 pm
For the altezza 3sge beams fuel entry is on the top (above where No 3 injector is) with both ends of the rail blocked off (blind fuel rail)
here is a close up photo
Not sure about the red top beams though..
nz_climber
Postby iOnic » Sat Jan 05, 2013 6:54 pm
From memory it's the throttle body end.
Why?
I had to ask...
Postby tractionfree » Sat Jan 05, 2013 7:12 pm
thanks guys. engine is from a st215 caldina, inlet is on one end, outlet is on the other, so a little different to the altezza unfortunately
putting a beams into an sw20 and had a bit of a brain fart looking at the fuel plumbing, at first glance the regulators on either end looked identical, and the gen2 3sge has the vacuum-referenced regulator on the non-TB end, so i had it hooked up that way
upon closer inspection, the TB end on the beams engine HAS a vacuum reference, while the non-TB's fitting is actually a banjo fitting under what looks like a dummy regulator.
short version: fuel enters the rail via the banjo fitting on the non-TB end, returns out vac-referenced regulator, TB end. this could be caldina-only though (everything else seems to be bloody different too!)
tractionfree
Postby iOnic » Sat Jan 05, 2013 7:24 pm
One of those is a pulsation damper.
Postby nz_climber » Sat Jan 05, 2013 7:25 pm
Ahh, yeah thought you must be talking of the red top version after I had written most of my reply. Glad you got it sorted
nz_climber
Postby RomanV » Sat Jan 05, 2013 10:47 pm
Although there's a port for vaccum reference on the FPR, it isnt connected to anything from factory.
Dont need a vaccum line to it.
Just fuel in fuel out.
Users browsing this forum: Google [Bot] and 38 guests
