Al wrote:Top feed injectors are a heap cheaper than side feeds. You can get a set of large (720cc, 850cc, 1000cc, 1200cc) top feeds plus the new fuel rail and fittings for less than a set of 800cc side feeds.
I guess it depends on how carried away you get with buying the parts needed, there are some quite spendy items avaliable
gt4dude wrote:i think were in the same boat as far as injectors go, we got a side feed rail, so our options are limited as far as injectors go, i think sard make an 800cc drop in 3sgte injector
Yip not alot of options to choose from.
gt4dude wrote:the low impedence, high impedence shi t has to do with how much current the ecu injector drives can put out and the resistor pack in our factory loom, some people i guess when they deloom their car also remove those stupid alloy heatsink looking things from their cars and just get high impedence injectors
Interesting so to run high impedence injectors I woud need to bypass the resistor??
Heylin wrote:Ended up going with SARD 800cc side feed and dual feeding the factory rail, plenty of fuel for 205 rwkw, injectors were running low duty cycle with plenty left in them.
Look out on eBay for good deals on SARD side feeds, WolfKatz also do injector packages and rail options for the 3SGTE, could be good value with the current USD.
Awesome thanks for that website, could be quite handy with sorting out everything fuel wise
Will keep an eye out on Ebay over the next couple of weeks, but would definitely prefer new parts.
gt4dude wrote:i never got a chance to look at the factory rail,
ive heard theres some casting crap around the inlet and outlet that can be bored out, but whats the bore like inside the rail ?? is it not very wide in there either?
also, dual feeding the rail does this mean you tapped in a new return port between 2&3 or did you just put a T-piece somewhere on the fuel line?
the bore on the Gen 2 and 3 fuel rail is machined after the rails are cast, I've read (on the interwebs) that it is possible to bore the rail out abit to allow more fuel to sit in the rail.
As for the dual feed, on a Gen 2 fuel rail there is a outlet for a cold start injector, which can possibly be used as a return port. Would need to custom make something up for a Gen 3 rail.
strx7 wrote:if you changed your inlet manifold (maybe not required) you can use a 3SGE top feed rail and top feed injectors. i used 720cc 12a turbo injectors in a 3sge rail on my 3sgte stroker and an msd external pump, had plenty of fuel in reserve at 270awhp @ 15psi.
Am currently running a sidefeed intake manifold off a ST162 3SGE, so have plenty of room to fit any rail setup in there.
I actually have a complete ST182 3SGE, so might have to do a test fitment on a 3SGTE head to see what I'm able to do, this is probably at the top of list, as it will be cheaper and with abit of research, could possibly have enough flow.
