strx7 wrote:with the same boost you can run more advance which means more HP from the same CFM (and therefore same psi)
diss7 wrote:My line of thinking, is that power is related to the turbo. As the entire setup is governed by the turbo, as power is realitive to the quantity of air. As I plan on running the turbo at/near capacity, I would see no gain.
I'm not saying that more timing could be added, but again, how would it result in more power if the boost pressure remains the same??
gt4dude wrote:On a similar note,
I'm tuned for 98, to run E10, should I blanket my fuel map with +3.3%?
E10 from my understanding is 95+10% ethanol, with a total octane rating of 98, i'm guessing this means i cant add any extra timing?
gt4dude wrote:ahh i dont want to lean out either, my tune is pretty good for AFR its as linear as possible starting from 13.5 in low revs and falling to about 12.5 by the redline
but my ignition advance is on edge (engine especially prone to knock due to head and block skimming)
i was just wondering if +3.3% was the correct amount to add to my injector correction, and if that increase is directly proportional to the net result of 3.3% more fuel per cycle, etc
gt4dude wrote:I searched all over google looking for the answer to my question, couldn't find anything definite. All I could find was that ethanol requires approx 33% more juice than petrol to make the same Lambda, so since its only E10 I got 3.3% from 33%
the final row of load cells in my maps will become unavailable to me as my duty cycles will exceed 100% so this means a max boost of approx 1.1-1.2bar and possibly a 6800rpm limiter
apex pfc has its own method for calculating load points based on a mix of TPS and MAP
