Brake master cylinder 1 inch or larger.
Postby Grrrrrrr! » Sun Jan 20, 2013 2:34 pm
Okay, I need some help identifying what car (probably a 4wd actually) this master cylinder comes out of. Want a firmer pedal with a bit less bite in the race car for better brake modulation.
The key aspects are.. 4 bolt mounting, 1 1/16th Bore and ideally both fluid ports exit horizontally and perpendicularly like the middle two in the pic below. If you happen to have the one at the end let me know, shouldn't cost too much to get new hard lines made up.
In the US of A they come from mid 90s Tacomas and T100s. Which i think translates to 4runners and ??? over here.
So, if you have a surf, landcruiser or similar land yacht parked in the driveway, i would really appreciate it if you could pop the bonnet and see if you have the one i'm looking for.
If you have one, can you let me know the details Make/Year Chassis Code/ ABS or Non etc. so i can harass Mark for a price for one.
I'm also interested in 1 inch bore, and for bonus points you have a spare good condition one in the garage you want to send my way for not much money! (Dreams are free ..)
Grrrrrrr!
Postby RomanV » Sun Jan 20, 2013 3:48 pm
I had similar situation, took my existing one to BNT and they just fished some out of the packets and found one that was sweet.
Postby Grrrrrrr! » Sun Jan 20, 2013 4:08 pm
Yep, trying to find to do that during the week is the problem atm, and would like to have car on road next weekend with new master cylinder. If i have to pull one out and go harass them on staurday I will.
Grrrrrrr!
Postby Grrrrrrr! » Sun Jan 20, 2013 10:00 pm
Dropped some mr2 parts off to a guy who had a 4runner on the lawn, so i know where the 1 inch master cylinder comes from. LNR130.
Would be keen to know where the 1 1/16th one comes from tho.
Grrrrrrr!
Postby Crucible » Mon Jan 21, 2013 12:46 am
A brake specialist or parts place like bnt who handle or rebuild alot of master cylinders will probley be able to help
Crucible
Real Life Mechanic
Users browsing this forum: Bing [Bot], Google [Bot] and 35 guests
