Runx gearbox noise on deceleration - WTF?
Postby theDiff » Thu Jan 31, 2013 9:56 pm
I have recently bought a 2001 Runx Z and all is going well, until I decelerate on the motorway from around 100kmh to below 85kmh.
When I do this (in 5th gear but take my foot off the gas) a weird noise occurs which you can hear at 10 & 16 secs in on this video:
http://www.youtube.com/watch?v=soACa9cCfw0
When I accelerate it goes away. When I engage the clutch it goes away. It only seems to be happening at certain speeds and is more pronounced in 5th gear. Have any other Runx owners had a similar issue?
One guy I know says its just the gears running against each other and his Runx used to do it too and that it was normal. Another says its the run bearing which is poked.
Anyone else got any ideas? Your help appreciated :)
theDiff
Postby iOnic » Thu Jan 31, 2013 10:00 pm
Postby theDiff » Thu Jan 31, 2013 10:10 pm
Cheers - for that!
Forgot to mention that it has had its clutch replaced with a heavy duty one about 30,000km ago... While it is noisy, and other have said these cars are noisy on deceleration, I think it might be a bearing issue.
Seems to be common. Anyone have a ballpark figure of the cost on replacing them?
theDiff
Postby CAMB01 » Fri Feb 01, 2013 10:00 am
Sounds like gear chatter to me. Wonder if the clutch that was installed is a solid centred one.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby theDiff » Fri Feb 01, 2013 10:18 am
I have the invoice from the previous owner at home, will take a look...
theDiff
Postby CAMB01 » Fri Feb 01, 2013 1:10 pm
Also the thread that iOnic posted up could be the problem, as it is quite common.
CAMB01
Postby theDiff » Fri Feb 01, 2013 2:32 pm
I agree - I think its somewhere between the clutch and gearbox. I guess it'll be a case of getting it looked at and figuring it out once and for all!
theDiff
Postby theDiff » Tue Feb 12, 2013 9:30 am
Changed the fluid and put some way better stuff in there. The chap who made the change is 99.99% certain it's a bearing issue and that it will need changing in the near/medium term.
Anyone know of a decent transmission specialist in Auckland? Also, anyone know the ballpark figure for replacing all bearings in a C64 gearbox?
theDiff
Postby RS13 » Tue Feb 12, 2013 8:56 pm
Just as an add-on to what I said in that other thread, I went for a drive in my sisters' RunX Z again, the gearbox sounds much worse.. very surprising for a 70,000km car.
RS13
Postby matt dunn » Tue Feb 12, 2013 9:02 pm
theDiff wrote:I have the invoice from the previous owner at home, will take a look...
did you ever find out if the clutch was solid centre or not?
had the same in my old EVO and most gearbox places said was in the box,
but i had just fitted a HD clutch with a solid centre and a new standard clutch plate fixed it.
Postby CAMB01 » Wed Feb 13, 2013 9:36 am
matt dunn wrote:had the same in my old EVO and most gearbox places said was in the box, but i had just fitted a HD clutch with a solid centre and a new standard clutch plate fixed it.
I get disgusted and weird looks when i lift off the gas in my EVO now with the new solid centered clutch. Its friggin loud gear chatter that resonates through the driveshaft :(
CAMB01
Postby theDiff » Thu Feb 14, 2013 3:49 pm
I'll have to check the invoice fro the heavy duty clutch that was put in there. Will come back to you tonight.
theDiff
Postby theDiff » Wed Mar 27, 2013 1:47 pm
It wasn't the gearbox, had that checked and it's sweet. Had the clutch replaced with standard, had the tension pulley replaced, had the drive belt replaced and there is still a noise!
theDiff
Postby Millhouse1 » Thu Mar 28, 2013 9:37 pm
I wouldn't worry about it too much. My Allex RS180 (same car) does the same thing. Just a noisy gearbox. I put some Redline gearbox oil in (to help with sticky downshift- helped greatly with this), but this didn't make any difference to the gearbox noise. It's never got any worse. We had a Celica that did the same thing & never got any worse.
Millhouse1
Postby allencr » Fri Mar 29, 2013 4:49 am
theDiff wrote: ....had that checked and it's sweet.
How did that happen, disassembled by someone with years of experience, or just flogged around by someone almost like you but with more confident BS??
allencr
Postby theDiff » Tue Apr 02, 2013 1:02 pm
allencr wrote: disassembled by someone with years of experience
Yes :roll:
theDiff
Postby theDiff » Tue Apr 02, 2013 1:05 pm
Millhouse1 wrote:I wouldn't worry about it too much. My Allex RS180 (same car) does the same thing. Just a noisy gearbox. I put some Redline gearbox oil in (to help with sticky downshift- helped greatly with this), but this didn't make any difference to the gearbox noise. It's never got any worse. We had a Celica that did the same thing & never got any worse.
Yeah - I think I'm being pedantic now. Comparing that YouTube clip to how the car sounds now and it's much better. And you're not the first 2ZZ-GE engine owner to say their gear box makes a bit of a racket. Oh well, glad we sorted that out :D
theDiff
Postby Weegee » Tue Apr 02, 2013 5:01 pm
mine makes a racket on decel as well if that helps.
'96 AE111 Trueno BZG (sold)
'01 ZZE123 Runx Z
Weegee
Postby theDiff » Thu Apr 04, 2013 9:00 am
AND THEN THE ALTERNATOR BLEW UP! Which I'm now guessing was the issue. Perhaps on deceleration the pulley was having a spaz and making a weird squeal?
theDiff
