Will blacktop cambelt covers fit a silvertop
Postby ryanfels » Thu Feb 07, 2013 10:36 am
Hey guys (and the few girls)
ive got a a silvertop block with a blacktop head. its currently fitted with the lower silvertop cambelt cover. I want to know if the blacktop cambelt cover will fit over the silvertop oilpump/tensioner system or will i have to stick with the silvertop gear?
Does that make sense?
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
Postby XSVWGN » Thu Feb 07, 2013 1:28 pm
They swap over. I have never had any issues with my 4age engines
2008 Kia rio - work car
XSVWGN
Postby gasman » Thu Feb 07, 2013 2:53 pm
i think you can swap them over but you cant mix and match black and silver covers, need the full set from either one.
"What can possibly go wrong?"
gasman
Postby matt dunn » Thu Feb 07, 2013 8:18 pm
both wrong there,
The bottom one doesn't fit as the mounts are in a different location due to the hydraulic tensioner,
the middle one is also different as the water pump is also different as the part of it where the cambelt cover goes is moved to give clearance to fit the hydraulic tensioner wheel.
So no the BT covers do not fit a ST oil pump and water pump.
Postby tsoob » Thu Feb 07, 2013 9:21 pm
what middle one do you use with the 4agze bottom and silvertop head?
I need the middle cover
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby XSVWGN » Thu Feb 07, 2013 10:35 pm
Pretty sure I have a blacktop one nick.
XSVWGN
Postby tsoob » Fri Feb 08, 2013 1:27 pm
XSVWGN wrote:Pretty sure I have a blacktop one nick.
im running the silver top covers, they look better... so i need a middle cover do you have one that works?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Users browsing this forum: Google [Bot] and 21 guests
