Cable for battery in boot
Postby Rob » Sun Mar 10, 2013 4:18 pm
As per the title, what size cable should I run to put a battery in the boot of my ST185? and also is running an earth back to the engine a good idea?
Cheers for the help
Rob
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby steroidcontaskie » Sun Mar 10, 2013 4:58 pm
Not sure if there is a rule of thumb or not. But for my soarer I ran 0 guage to the boot and ran the ground to the chassie under the boot. Havent had any problems with that setup, but I guess running it back to the factory earth would be technically better
Ed
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby loudstealthGT-Four » Sun Mar 10, 2013 6:55 pm
^^^ +1
I run a 0 gauge wire to the boot for the positive and then just earthed the battery in the boot, no issues in the last 2ish years
loudstealthGT-Four
Postby 92mr2paddy » Sun Mar 10, 2013 7:21 pm
yea same here works fine, dont wory bout running back to front of car as the whole car acts as 'earth' so anywhere works fine, and the shorter the less wire you have to buy for the earth so thats a win, hah
92mr2paddy
Postby holden_fan2005 » Sun Mar 10, 2013 7:24 pm
Same as above. Talk to ya local auto sparky as they can get decent quality cable generally for a good price. I ran my earth back to the block and also to the boot but I might remove that as others don't seem to be having issues (and I don't have any electronics)
holden_fan2005
Postby Rob » Sun Mar 10, 2013 8:29 pm
Thanks guys. Now what size is 0 gauge? and I would assume double insulation is best?
Rob
Postby allencr » Sun Mar 10, 2013 9:49 pm
Rob wrote:...assume double insulation is best?
It's more no chaffing, no pinching, no rubbing- preventing insulation problems rather then only relying on it.
allencr
Postby Grrrrrrr! » Sun Mar 10, 2013 10:05 pm
0 gauge is pretty damn beefy. Its about 9mm diameter of stranded copper.
Strangely enough thats about the size of the cable to the starter motor in an MR2.. And I happen to have one that i'm getting ready to send to scrap. Want me to try to pull the cable for you?
Grrrrrrr!
Postby RomanV » Sun Mar 10, 2013 10:10 pm
I've done exactly that, used an MR2 cable for a car with engine in the front, battery in the back (opposite if what SW20 is)
It works well, If need be I'd do it that way again.
Saves wondering if it will work or not, big enough wire or not, etc etc when you are using a factory part exactly as intended.
Postby Stott69 » Sun Mar 10, 2013 10:13 pm
Keep in mind that a fuse in line will be a good idea if anything does wear through. When I did this to my trueno I used a kill switch to join on to the old positive cable
Stott69
Postby RomanV » Sun Mar 10, 2013 10:14 pm
Oh yeah. I used part of the SW20 fusebox as well as the cable, mounted to the side of my battery box...
The whole thing goes through a 100amp fuse from memory.
Parts scavenging ftw :lol:
Postby Bling » Sun Mar 10, 2013 10:25 pm
Postby Grrrrrrr! » Sun Mar 10, 2013 10:35 pm
100 amp fuse? Yeah, Nah.. thats not going to handle cranking a 3sgte on a cold morning.
3sgte starter is rated at about 1.5kW which at 10Volts is 150 amps. 200Amp fuse would be minimum i'd even think about using and even then i'd make sure I carried a larger rated spare at all times for the first 6 months or so. Starter motor cable in an MR2 (and AFAIK most other cars) is not fused at all. The alternator Fuse in an MR2 is 120Amp, and thats a piddly little cable (4ga?) compared to the starter motor cable. Just think about how many Cold Cranking amps batteries are rated at.. 400+
Grrrrrrr!
Postby steroidcontaskie » Sun Mar 10, 2013 10:43 pm
I also thought that 100 amps wouldn't be enough, so I put a 100 amp breaker on the cable at the engine bay end and a 150 amp fuse just after the battery in the boot. My 2jz starter is meant to be 1.6kw but it doesn't even trip the breaker
. So I wouldn't be surprise if you where ok with 100amp fuse, but I would go for higher with a breaker in the engine bay.
RVR Turbo (idle)
steroidcontaskie
Postby Grrrrrrr! » Sun Mar 10, 2013 10:50 pm
Thermal breakers are SLOW.. you'd need a good 30secs of cranking before you had a chance of popping that. Surprised the fuse hasn't popped in the middle of winter tho.
Grrrrrrr!
Postby steroidcontaskie » Sun Mar 10, 2013 10:59 pm
Probably haven't run the car in winter yet, but I did spend a good 60s cracking the engine over on the starter last September. But Grrrrrr is right, go with 200+ amps, no down side to being a bit on the large side, but lots of problems if you are too small (or so I have heard :wink: )
RVR Turbo (idle)
steroidcontaskie
Postby XS1V » Mon Mar 11, 2013 7:44 am
I have a length of 0 gauge cable here on the shore if your interested, normally $25-$30 a meter otherwise :)
Brad
ST205 Group A Rallye #2363
XS1V
Users browsing this forum: No registered users and 38 guests
