S54 gearbox rebuuild info
Postby xsspeed » Mon Mar 25, 2013 11:57 am
Hi Guys, does anyone know any good resources for S54 gearbox dissasembly/reassembly/rebuild etc.
Initially I just want to pull the diff on one. I presume they are very similar to a c52 gbox. I beleive on C series boxes you undo the end section, pull 5th gear, then remove the rest of the case to get to the diff/other gears. Does that sound right?
