Water vs coolant
Water vs coolant
Postby steroidcontaskie » Sat Apr 06, 2013 3:10 pm
Hi guys,
I have been looking at some daily drivers and found one that seems pretty good. The only thing that seemed odd was that it had water instead of coolant in the cooling system. Water was clean though.
Does this throw up any alarm bells about the car?
Edward
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby eskimo » Sat Apr 06, 2013 3:29 pm
Cheap skate owners / mechanics :?
If its clean id just flush it out and replaced with the correct coolant/water mix
Jordon
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby Adoom » Sat Apr 06, 2013 4:58 pm
eskimo wrote:Cheap skate owners / mechanics :?
Jordon
<Thread Hijack>
Correct me if I'm wrong, but it was my impression that adding "coolant" to water was to lower the freezing temp, raise the boiling temp and as a corrosion inhibitor for alloy heads/blocks? But it actually reduces the effectiveness of the water for cooling...
AFAIK it doesn't really get cold/hot enough in most of NZ to need the "coolant".
Has anyone got any idea how long, in practice, it would take to see any detrimental corrosion effects from running straight water?
FYI: I do actually use "coolant" in my engine.
</Thread Hijack>
Adoom
Postby evil_si » Sat Apr 06, 2013 5:29 pm
In a diesel engine in a road truck for instance, running no coolant.damage to the point of requiring an overhaul, wet liners etc can be in as little as 50,000km, that damage can be done in a couple of months,
evil_si
Postby Dell'Orto » Sat Apr 06, 2013 5:45 pm
Jordon
<Thread Hijack>
</Thread Hijack>
Correct, but you certainly want some form of corrosion inhibitor in there, shit will rust pretty quickly.
Postby BZG Wagon » Tue Apr 09, 2013 9:19 pm
If you're going to buy it I'd:
1) Squeeze the rubber water pipes all around the engine. If they feel 'crunchy', than you have corrosion problems.
2) Pull out one of the frost plugs and see what sort of condition it is in. Again check for corrosion (coolant prevents corrosion).
3) Turn the heater on hot, then cold, then hot, then cold. If there's any lag between going cold & hot (or if it won't get really hot) then you have blockages somewhere.
4) Go for a long, hard drive (look for some decent hills) and see if the temp spikes. Once warmed up the gauge shouldn't move at all (usually sits just a tad under half way on most cars). Coolant helps disapate engine heat and raises the boiling point of water.
If any there's any evidence of the above I'd personally stay away (unless you're getting an absolute bargain and love the car).
BZG Wagon
