turbo question on this GT86
Postby dnalunchie » Thu Apr 18, 2013 5:39 pm
about half way down the article it says that the car is "technically forced induction but with no turbo in the way to muffle up the sounds it sounds more like NA"
http://www.speedhunters.com/2013/04/the ... performer/
I am curious as to why this is? is there something special about the way the turbo has been mounted or is it something about the FA20 engine? just couldnt work out what they meant.
Current: 90 3sfe Corona
dnalunchie
Postby sergei » Thu Apr 18, 2013 5:43 pm
It is a mechanical supercharger.
The centrifugal variety.
http://en.wikipedia.org/wiki/Centrifuga ... percharger
Postby rolla_fxgt » Thu Apr 18, 2013 7:25 pm
I think the comment about being technically force inducted is about the fact the supercharger presurises the engine above normal intake pressures.
I'm sure someone with more technical know how will say it better, or tell me I'm talking out my arse
rolla_fxgt
Postby Lloyd » Thu Apr 18, 2013 8:01 pm
A turbo will change how the exhaust sounds, there is no turbine in the exhaust system with a mechanical supercharger, hence the exhaust note should be more like an N/A. That's all they're saying
Postby dnalunchie » Thu Apr 18, 2013 9:48 pm
Lloyd wrote:A turbo will change how the exhaust sounds, there is no turbine in the exhaust system with a mechanical supercharger, hence the exhaust note should be more like an N/A. That's all they're saying
ah cool, thanks man.
dnalunchie
Postby matt dunn » Thu Apr 18, 2013 10:12 pm
Turbo's are quite good mufflers.
Most turbo race cars don't need mufflers.
That thing definately would.
Postby Lloyd » Thu Apr 18, 2013 10:28 pm
Yeah, it's quite impressive how well they work. Had a van a while ago with no exhaust from about 2 feet behind turbo and it was as quiet as most cars. And the AE92 GTZ got the exhaust done before the turbo setup so was just supercharged for a while. Extremely loud until the turbo went on and then it was nice.
Postby steroidcontaskie » Sat Apr 20, 2013 10:42 am
Been a while since I read up on them, but I thought that centrifugal superchargers were poos. Just like a turbo, but they drain engine power to run them. Pretty sure no company uses them factory on a car, I guess they are easier to fit in a car, but if you were going to that kind of effort why didn't they just turbo it?
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby Mr Revhead » Sat Apr 20, 2013 10:54 am
Hugely popular in the USA bolt on market.
Like any mod, they have the best points and neg points.
They take less to drive them that a Roots type
Postby jacobrjett » Sat Apr 20, 2013 10:54 am
as far as i was aware all superchargers drain engine power.
twin screw, centrifugal etc. belt driven off the crank.
jacobrjett
Postby rollaholic » Sat Apr 20, 2013 1:42 pm
who cares if its not as efficient as a turbo, if it makes more power (than the stock engine) then the car is faster.
thats the point after all?
has plumbing benefits etc too eh
probably made up for by the mounting issues :P
Postby Grrrrrrr! » Sat Apr 20, 2013 1:49 pm
jacobrjett wrote:as far as i was aware all superchargers drain engine power.
So do turbos.. great big restriction in the exhaust, and lower compression to stop the engine going pop all costs power.
Grrrrrrr!
Postby gt4dude » Sat Apr 20, 2013 1:59 pm
^---- exhaust turbine is wasted energy being harnessed
belt driven compressor is worst of both worlds - turbo lag and accessory drain
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby RomanV » Sat Apr 20, 2013 2:22 pm
Boost threshold =! lag.
There's an aussie guy with an MR2 running a beams motor with one of those superchargers, makes bloody good numbers all across the rpm range, with instant throttle response.
Turbo isnt necessarily a free lunch either.
Supercharged 2GRFE is the answer :D
Postby Alex B » Sat Apr 20, 2013 2:51 pm
There goes my idea for a perpetual motion engine, $&#$% it.
Postby Bling » Sat Apr 20, 2013 4:44 pm
I'm pretty sure all petrol engines consume petrol too. Another fun fact to add to the above technical advice.
Postby Lloyd » Sat Apr 20, 2013 5:09 pm
Not if you drive everywhere in reverse, then they actually produce fuel
Postby Mr Revhead » Sat Apr 20, 2013 5:16 pm
Reverse with centrifugal a/c perpetual motion engine..... Poof goes my mind
Postby Lloyd » Sat Apr 20, 2013 6:10 pm
Keep it to yourself otherwise you may find certain people knocking on your door
