ECU pin out help
ECU pin out help
Postby Stott69 » Sun Apr 21, 2013 2:17 pm
Trying for the last half an hour to find pin outs on the JZS147/jza80 ecu. I need :
RPM
Throttle Position
Map sensor
Ignition =12v
Earth
But can't find a metion of there being a RPM signal at the ecu, can anyone help me on this please?
Stott69
Postby iOnic » Sun Apr 21, 2013 2:28 pm
Is an "NE" signal mentioned?
Btw sometimes the pinout is printed on the ECU PCB. Whip the cover off and look.
Postby Grrrrrrr! » Sun Apr 21, 2013 2:34 pm
Rpm signal to/from what?
Chance are its just one of the igniter signals if its for the tacho
http://wilbo666.pbworks.com/w/page/41678224/2JZ-GE%20JZA80%20Supra
29 Engine Mounted Diagnostic Connector: IG- Tachometer Output from Igniter Output The body loom side of this pin needs to be connected to the dash tachometer.
The engine loom side of this pin connects to the diagnostic connector IG- pin mounted on the side of the engine and the igniter tachometer output pin which connects to the coil negative via the igniter.
Grrrrrrr!
Postby Stott69 » Sun Apr 21, 2013 2:37 pm
Oh more info, its to install an HKS Super AFR
Stott69
Postby iOnic » Sun Apr 21, 2013 2:39 pm
^ Judging by the pins he's looking for I'm gonna hazard a guess and say he's looking to piggyback an aftermarket ECU onto the factory ECU so the engine speed he wants is the crank position signal which Toyota usually calls NE and there is/are also cam sync signals (G, G1, G2 etc)
Just off the top of my head. I dont know too much about jz specific engine management.
Postby JZCrazy » Sun Apr 21, 2013 5:37 pm
JZCrazy
Postby JZCrazy » Sun Apr 21, 2013 5:38 pm
Page down and click on pdf under pinout pic.
JZCrazy
Postby JZCrazy » Sun Apr 21, 2013 6:12 pm
Not sure how the HKS AFR works, but as has been mentioned above you can pick up a signal from IGf. Pin 58.
I used the IGf (feedback) wire to my Innovate, for RMP signal on my 1JZ.
Not sure about the TPS. I'm thinking it would be VTO1. Pin 40.
JZCrazy
Postby JZCrazy » Sun Apr 21, 2013 6:35 pm
Had a quick squiz through my stuff and have found a set of wiring diagrams for the 2JZGTE and the GE. (only the ecu)
Can send them through if you want them.
JZCrazy
Postby Stott69 » Sun Apr 21, 2013 7:00 pm
Its mainly figuring out which pins to use, seems to be a few opinions on which pin to use for which
Stott69
Postby JZCrazy » Sun Apr 21, 2013 7:43 pm
Yeah, looks like this unit would be a piece of piss to wire up to a 1JZgte.
I am thinking pin 40 isn't the right one.
How many wires to your MAP sensor?
JZCrazy
Users browsing this forum: Google [Bot] and 36 guests
