suspension camber etc
Postby dnalunchie » Fri May 03, 2013 7:55 pm
I have a question
When you take a car in to have its suspension alignment checked how does the show know what to set the castor and camber etc to ? I am assuming that performance based cars that have some adjustability would have pretty specific settings to perform best so how is this choosen/set?>
Current: 90 3sfe Corona
dnalunchie
Postby Lloyd » Fri May 03, 2013 8:05 pm
They'll have a list of factory specs, much like how you get books of torque settings for specific engines etc
If you get a wheel alignment done at Firestone then you'll get a print out of that particular models maximum and minimum settings for each setting as well as the before/after settings for the vehicle they worked on.
Postby Bling » Fri May 03, 2013 8:37 pm
Have you really never had an alignment done and got the print out? 8O
Postby iOnic » Fri May 03, 2013 8:47 pm
^ this. They set it to what it's sposed to be. Unless you request otherwise.
Postby dnalunchie » Fri May 03, 2013 8:50 pm
ah okay, and what if you buy something like a castor or camber kit for a car? would it come with reccommended best settings ?
dnalunchie
Postby phoenix » Fri May 03, 2013 9:08 pm
You should know what settings you're after before you buy the camber or castor kit.... Isn't that why you're buying it?
phoenix
Postby Lloyd » Fri May 03, 2013 9:11 pm
If you're modifying suspension angles and ride height etc then there wont be any best recommended settings. It'll be completely different on every car and up to the owner to decide what they want really.
Postby 1I1 » Fri May 03, 2013 9:15 pm
Lloyd wrote:If you're modifying suspension angles and ride height etc then there wont be any best recommended settings. It'll be completely different on every car and up to the owner to decide what they want really.
This. Will come down to how the driver wants the car to handle. And then you either have to tell the place what you want the settings to be or take it to a speciality alignment place that does race setups etc
TRD Clicky >>Here
1I1
Postby wde_bdy » Fri May 03, 2013 9:55 pm
Most places you go to will have trouble working out what can even be adjusted on your car. Work on the assumption that the "expert" doing your wheel alignment knows less than you do.
Callum
wde_bdy
Postby Lurkin » Fri May 03, 2013 10:17 pm
^this.
In the end I think I got my alignment suggestions off here.
Really depends on the vehicle.
Past casualties
1986 4age liftback (sold)
Lurkin
Postby Truenotch » Fri May 03, 2013 10:42 pm
Take it somewhere that sets up racecars. Should be a few places in Dunedin?
Truenotch
Postby dnalunchie » Fri May 03, 2013 10:59 pm
ah this is a totally hypothetical question, I dont know that my corona will benefit from a bit more camber. Was just wondering as was reading a thread about someone fitting some antilift kit etc and that it altered the camber/castor and I wondered how you would know what was the best/right set up specs
dnalunchie
Postby sergei » Sat May 04, 2013 8:25 am
dnalunchie wrote:ah this is a totally hypothetical question, I dont know that my corona will benefit from a bit more camber. Was just wondering as was reading a thread about someone fitting some antilift kit etc and that it altered the camber/castor and I wondered how you would know what was the best/right set up specs
your corona will benefit the most from replacing all the worn components with OEM stuff. As all of the bushes and shocks will be stuffed. Passing WOF does not mean that bushes and shocks are in good and working condition. but then it will cost you the cost of the car to replace all of that... far better off saving for your sti, since it is just an old corona.....
Antilift kit is great (I have it in my 165), not sure how it will work in FWD.....
Postby Akane » Sat May 04, 2013 11:18 am
Don't go nuts on camber, it's stupid. You lose braking ability, basically you're turning your car's handling into shit for "fatlace" and "stance".
Postby touge_ae101 » Sat May 04, 2013 11:46 am
Akane wrote:Don't go nuts on camber, it's stupid. You lose braking ability, basically you're turning your car's handling into shit for "fatlace" and "stance".
camber is one of the many geometry's/components which attribute to how a car handles. I agree in general public/average boyracers car will handle like shit with heaps of camber. not to say that it won't work on some cars. my ae101 is a perfect example. camber and castor compensated for soft springs and swaybars as a compromise between road and track suspension.. worked awesomely on the road - would be a good targa setting but to get the full potential of the cars handling capabilities I need harder springs less camber to make the tyres work properly
there are a lot of alignment places out there that don't know what they are talking about. standard settings aren't going to make your handle the best they are developed for tyre wear and understeering on the road. some later model cars such as Evo's have a choice of two different alignment recommendations depending on the customer.
probably most importantly its better to get to know your car, explain the symptoms of what you want to change to a racecar alignment specialist and get them to drive the car. they will make recommendations/changes based on your driving style and experience.
Adding camber, castor and bump adjusters etc for the sake of it is gay. it should be there to be functional.
touge_ae101
Postby Flannelman » Sun May 05, 2013 10:41 am
Changing the camber also affects tyre wear. More camber may help with cornering in some cars but it does come at a cost to tyres.
As a race car, maximum grip for a tyre is paramount so the suspension is set that max grip is for a set amount of laps. No point loosing 2 seconds a lap just so the tyres can go 10 more laps before changing if the car needs to be refueled 5 laps earlier.
However, on the road is far different. Those same suspension settings wont be kind on tyres resulting in changing them within 5000km. Stock settings wont give the best handling, but when driven nicely, will return tyre wear in the 25-30,000km. As a daily driven car, running cost is paramount or you will be taking the bus or riding a bike so you can afford to drive your beast in the weekend.
The Flannel, formally known as Affroman
Flannelman
formerly known as Affroman
Postby tsoob » Mon May 06, 2013 11:09 am
Depends on what you are setting the car up for. A drift spec alignment is miles from what you would do with a circuit car, and again miles from your average street car.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby d1 mule » Tue May 07, 2013 2:18 am
dont spend money on a 89 corona...... simple
d1 mule
Users browsing this forum: Google [Bot] and 47 guests
